play store auth issue
twice now the lay store says I need to authenticate when I try to install something, and then it doesn't.  all other google sign in stuff seems to work fine, just the play store.  only a reboot fixes it and then the thing installs fine.
arg! now it's sucessfully installing one thing, then nothing else!
I'm also now getting a generic error with a link to a web page that tells me how how ot make sure my network connection is OK. a web page. on the internet. that loads fine. thinks my network isn't connected.
I realize that one is all google's fault, but damned. this is nuts.
(05-04-2016, 07:49 PM)chrwei Wrote: twice now the lay store says I need to authenticate when I try to install something, and then it doesn't.  all other google sign in stuff seems to work fine, just the play store.  only a reboot fixes it and then the thing installs fine.
If next time happens again, goto setting-> app and clear the Play Store data. This may help.
i did clear cache. rebooting always fixes it
I am on android stable release 20160303 clearing cache or rebooting nothing works for this issue.
Created a new android image to boot, play store works fine for few hours again same issue.
Followed below step to download using play store:
* Go to Settings --> Account --> Google
* Select your google account --> select option (Three dots) on top right corner
* Select Remove account.
Launch play store it will ask to add google account.. Now it will work for sometime until you hit authentication issue again.
When I get to the point where I've entered my Google account information and I'm supposed to verify terms and conditions, I can't go any further. I believe there's a box that I need to check but am unable to see it. Can't figure out how to scroll down. Ideas?
tried clearing data, now the play store interface won't load at all, just a white screen with the loading spinner
Speaking from back when I used to play with lots of android roms on various phones it could have something to do with the scree density/resoloution being reported to google play or it could have to do with what device is being reported. Hard to say. Have any of you checked https://www.google.com/android/devicemanager to see if the play store saw the device try to login?
I'm having similar issues - feel the pain.
Guys, have you tried the new Android Image released 2 days ago? Do the problems persist under the new release?
(05-09-2016, 02:45 PM)g_t_j Wrote: Guys, have you tried the new Android Image released 2 days ago? Do the problems persist under the new release?
Haven't tried it yet, I'll try to give it a test tomorrow. I didn't seen anything in the release note about it so I figured it wasn't fixed.
  VPN issue on Pine64 pinea64.edison 4 10,395 06-27-2017, 12:25 PM
Last Post: milkaca
  No Intenet Access Need Help Diagnosing Underlying Issue Bob123456789 10 19,815 06-02-2017, 01:32 PM
Last Post: Bob123456789
Thumbs Up Kids love to Play Super Why App Erica Edwards 3 7,911 01-09-2017, 07:35 PM
  Play music won't play anything mikey0000 12 25,762 10-21-2016, 01:24 PM
Last Post: gezora
  (potential) work-around for Playstore authentication issue Luke 31 73,324 09-01-2016, 05:07 PM
Last Post: MarkHaysHarris777
  Can't download apps off Google Play! Bacon Strips 6 14,224 08-31-2016, 12:26 PM
Last Post: DonFL
  Games in Play Store top3b 2 6,372 07-26-2016, 12:40 PM
Last Post: top3b
  Play Store stops running every time thehamguy1 15 28,977 07-10-2016, 01:04 PM
Last Post: Raslin777@gmail.com
  Can't play movies from Google Play Store wappi 11 24,730 07-10-2016, 12:47 PM
  Widescreen gaming in Google Play DwyerSP 1 5,485 06-30-2016, 11:22 AM
Last Post: Tarjei85
