Apps
Hey everyone, I am pretty new to the pine phone and the programming of it. I have the mobian software on my Pine phone. How do I add apps to it? Thank You for any help.
Thank You
Chris
(11-27-2020, 03:02 PM)Csanderson0313 Wrote: Hey everyone, I am pretty new to the pine phone and the programming of it. I have the mobian software on my Pine phone. How do I add apps to it? Thank You for any help.
Thank You
Chris
Did you try the software app?
Thank You
Chris
Yes I did. I am limited on what apps that I can use.
The Software app has a history of being somewhat unreliable - it may work or may crash. Using apt from a terminal will be more reliable. You should be able to find tutorials with a quick search if you aren't familiar with it.
  New Install, apps start but don't show up on screen?! RT3 2 3,189 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,284 01-15-2025, 08:08 PM
  Keyboard not popping up on QT apps 3x5co 1 3,232 02-08-2024, 11:45 PM
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 2,614 07-17-2022, 10:34 AM
Last Post: 3x5co
  Using lat/lon in GPS/GNSS apps and Messaging biketool 6 9,047 05-04-2022, 11:45 AM
Last Post: wibble
  Apps and SD Card biketool 2 4,557 03-06-2022, 09:47 AM
  Reskinning Apps for Mobile biketool 6 8,733 12-05-2021, 02:30 PM
  no access to webdav files (for some apps) jsch 0 2,828 11-13-2021, 09:46 AM
Last Post: jsch
  Sizing apps to fit to screen county93 4 6,717 10-23-2021, 11:36 PM
Last Post: bcnaz
  What causes the long delays which switching or starting apps? motox6 10 15,686 10-17-2021, 05:58 AM
Last Post: vortex
