3D Printed PinePhone stand
I tried a few different stands for my PinePhone but they all seemed to be designed to be used only for display and/or charging and made the phone difficult to use.  So I decided to design a stand specifically for use during development and test.  The stand is strong and stable with a comfortable angle and allows you to use the touchscreen and buttons with one hand.  The design is in OpenSCAD and is GPLv3 - so feel free to use it an adapt as required.
https://github.com/simoninns/PinePhone-Dev-Stand
Here's a picture:
[Image: PinePhone_Stand_1_s.jpg]
Very cool. Hoping this reduces the USB cable falling out easily.
Thank you
LF
Nice!
Works like a charm. I found the fit between the tabs and slots was very tight. Other than that all the other problems were my newness to 3D printing. I think I will try to add a CE Dock holder as my first 3D design task.  It has been a very steep learning curve. Picture taken with my Pinephone
(11-17-2020, 10:28 AM)Lousy Fisherman Wrote: Works like a charm. I found the fit between the tabs and slots was very tight. Other than that all the other problems were my newness to 3D printing. I think I will try to add a CE Dock holder as my first 3D design task.  It has been a very steep learning curve. Picture taken with my Pinephone
Different printers have different tolerances; I tried to add a bit of slack into the slots; but it should be pretty clear in the OpenSCAD code what needs to change to make it even looser.
Anyway; glad it worked for you Smile  If you add in additional bits for the CE dock then you are welcome to make a push request to the github repo (or just link to your design and I'll include it if you are not familiar with github).
Nice work. I was inspired by your design, so I made something that was a little easier to print (also has a shorter print time and uses less material):
https://www.thingiverse.com/thing:4659409
[Image: featured-preview-pinephone-dev-stand-1.png]
EDIT: Made a second version that prints more quickly with less material, and makes it easier to plug/unplug the USB cable:
[Image: pinephone-dev-stand-v2.png]
"Imitation is the sincerest form of flattery."
Looks great Smile The more designs to choose from, the better.
Hello @simoni  and @arcanemachine,
Very nice jobs  Smile  I'm looking for something like that.
I've an idea, as yours stands are in two parts, could you find a way to fix the part with the hole for the USB-C cable in landscape position to use the Pinephone in landscape mode ?
(12-02-2020, 02:30 AM)Gribouille Wrote: Hello @simoni  and @arcanemachine,
I've been meaning to do that... If you want to check back in 2 or 3 days, I should have a new version ready.
If you don't want to wait (and are handy with FreeCAD), the FreeCAD files are in my Thingiverse link.
Hello @arcanemachine,
I'm waiting Smile
Thank you.
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,844 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 3,478 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 11,554 06-03-2025, 04:19 PM
Last Post: j_s
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,717 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 24,454 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 5,661 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,543 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 3,384 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 5,250 06-29-2024, 09:36 PM
  Was someone able to use the Pinephone keyboard & an usb mouse at the same? Peter Gamma 4 13,000 06-26-2024, 07:11 AM
Last Post: dachalife
