Cannot set Firefox or Calendar as default applications
Question
In the "settings -> default applications" menu, I can't choose "firefox" in the "web" dropdown (in fact, I can't choose anything), and so links from other applications open with the text editor. similarly, "text editor" is selected as "calendar", and it's the only option, despite having Calendar installed.
Is this a known issue? If not, where should I report it? And lastly: can these settings be changed from the command line?
You can set Firefox as default browser via Firefox > Preferences. There's a button to set Firefox as your default browser.
For calendar, I don't know.
(11-14-2020, 01:37 PM)davidbe Wrote: You can set Firefox as default browser via Firefox > Preferences. There's a button to set Firefox as your default browser.
Thanks, that worked for Firefox and in fact the app is now marked as the default web browser (see screenshot).
However, it is still weird that nothing appeared originally. Also, I have no solution for the calendar yet - I wonder if this can be changed from command line somehow?
[Image: qVMQi3K.png]
Have you installed a calendar program? gnome-calendar is an option.
Verstuurd vanaf mijn Wileyfox Swift met Tapatalk
Not trying to hijack the thread or something,
but for me some settings in Firefox are never being saved (e.g. added the history button to the toolbar, after restarting Firefox it was no longer there), maybe it is related?
(11-15-2020, 06:53 AM)davidbe Wrote: Have you installed a calendar program? gnome-calendar is an option.
Yes, gnome-calendar is installed by default.
  Firefox issue with latest update Barugon 6 8,593 01-28-2023, 01:29 AM
Last Post: alaraajavamma
  "Emergency" terminal on pinephone (with default setup) altulke 5 7,451 05-03-2022, 12:42 PM
Last Post: altulke
  Why is sshd installed/listening by default insidetrip101 0 2,512 11-14-2021, 10:29 AM
Last Post: insidetrip101
  Can i install 16 different distros apart from the default manjaro? temp0rary 4 7,947 05-28-2021, 03:55 PM
Last Post: temp0rary
  Firefox bar and content outside screen 112113101098101077 5 9,844 03-10-2021, 06:24 AM
Last Post: Nick_dnepr
  FIle Browser popup when sing Nemo/Calendar on Beta 4 nimji 5 10,020 01-28-2021, 03:29 PM
Last Post: kern707
Star [Updated] Let's see which applications are compatible with the PinePhone on Manjaro kern707 8 18,066 12-09-2020, 06:14 PM
Last Post: patrickmollohan
Shocked Possible reason why MANY applications dont work properly in Manjaro on the PinePhone kern707 4 9,845 12-04-2020, 09:46 AM
Last Post: kern707
