Is my wooden desk a safe surface to test the cluster board on?
And if not, what is? The plastic bag it came in? Anything metallic? I don't have a proper box at the moment.
Sure, why not? Earthing is usually provided by the power connection and a wooden table does not conduct electricity. Maybe make sure to discharge static current on yourself before touching it.
(06-07-2020, 09:43 AM)poVoq Wrote: Sure, why not? Earthing is usually provided by the power connection and a wooden table does not conduct electricity. Maybe make sure to discharge static current on yourself before touching it.
Sounds good, thanks!
As long as you don't spill water.
(06-07-2020, 08:39 AM)ollehar Wrote: And if not, what is? The plastic bag it came in? Anything metallic? I don't have a proper box at the moment.
Don't leave it on the bag it came with! I just did that because I wasn't paying attention when I plugged it in. It only took two second to start a fire. Now I am trying to figure out it I ruined the cluster board.
Anti-static bags are conductive! Don't use that or metal, or anything conductive. A wooden benchtop or desktop is ideal.
Wow, thanks for asking this ollehar! I was about to store this in a drawer inside the bag and had no idea that these are conductive or a fire risk.
  Buy Cluster and Compute Modules jpotter 1 5,552 01-10-2022, 04:01 PM
Last Post: dcdc
  What's the point of a cluster? guenther 2 8,055 04-07-2021, 10:49 AM
Last Post: guenther
  Add ordinary so-dimm memory to cluster slot? fxSol 1 6,505 03-02-2021, 03:54 AM
Last Post: poVoq
  Building a new cluster with external storage hvdkooij 2 8,245 11-20-2020, 07:44 AM
Last Post: hvdkooij
  Compatibility between RPi Module and Cluster board leperotero 1 6,052 11-03-2020, 03:40 PM
Last Post: poVoq
  Is there any way to get a video output from a cluster module? ollehar 4 11,347 06-16-2020, 12:34 PM
Last Post: ollehar
  What kind of box would be able to host both the cluster board and a RockPro64? ollehar 1 5,905 06-14-2020, 05:37 PM
  Just got my board ... Bazmundi 5 11,823 06-08-2020, 11:32 AM
Last Post: poVoq
  What's the difference between board v2.2 and v2.3? kazami2003 2 7,203 09-10-2019, 04:51 PM
Last Post: Unkn0wn
  Compiling on the Sopine Cluster khaosgrille 3 9,426 08-10-2018, 06:17 AM
Last Post: khaosgrille
