Emmc drive gone? Flashing with Jump Drive
 I wanted to flash the another os to the emmc drive.
Therefore I used jumpdrive 0.6 alpha to flash it (https://wiki.pine64.org/index.php/PinePh..._Jumpdrive, https://github.com/dreemurrs-embedded/Ju.../releases/)
the old os was mounted to /dev/sdb with sdb1 and sdb2 (root, boot)
No I can't find the emmc anymore. Guess, I would have need to mount it into the root partion only and not the whole emmc? So, the drive is gone forever or can it be flashed with uart?
(11-07-2020, 02:14 PM)muemmel Wrote: Hi,
what do you mean by "I can't find the emmc anymore" ?
what does this command output on your side ?
ls /dev/sdb*
it's strange that your usb media is so low in the assignments, does your computer have no removable media? i.e. optical/flash drives?
for me, it mounts at sdh, with sd{a-c} being hard disk drives, and sd{d-g} being optical and flash storage
anyway, you can shorten the above command to ls /dev/sd* to view your assigned drives that conform to the sd. standard, or you can consult lsusb to see if it's connected
Question PinephonePro can't Flashing to the eMMC ricardo 0 2,134 08-21-2022, 05:51 AM
Last Post: ricardo
  How to replace the home folder on eMMC ragreenburg 2 4,562 03-31-2022, 02:19 PM
Last Post: ragreenburg
  Problem Flashing the modem Firmware loreson 0 2,683 12-22-2021, 10:31 AM
Last Post: loreson
  Wipe out eMMC before flashing new OS? zkajdan 15 22,892 11-13-2021, 03:10 AM
Last Post: zetabeta
  Install OS directly to eMMC? tahayassen 11 25,399 10-10-2020, 03:56 PM
Last Post: electricprism
  USB Mass Storage is functional and makes EMMC installs very easy mestermagyar 1 6,520 03-15-2020, 03:43 AM
Last Post: mestermagyar
