11-11-2020, 11:35 PM
Mmmm I'm on 10th of November nightly, but I'm upgrading daily (apt-get dist-upgrade): which functionalities are broken?
Opinions wanted : "Best out of the Box" OS at this time
Thank you for the warning, I have been doing more testing. WIFI and Bluetooth off at the software level. Mobian apt updated to last nightWhen USB is connected screen suspend is flaky, When the screen does not suspend properly gnome-calls responds 100% of the time. There is no mobile data at any time, even immediately after boot
Test is an incoming call any time after the phone enters suspend after 5 minutes. The time slept appears to make no difference. 100% of the time the phone wakes up, (pick-a-number < 100% hours running) gnome-calls will present a UI to answer. My best pick-a-number is over 18 hours.My worst? Less than six minutes Min time to sleep is 5 min.Problem re-occurs 100% after the first time. so, the click VOIP phone on desktop, wait for the phone to wake, immediately login, but gnome-calls is not up. Manually opening gnome-calls results in a red bar stating modem not available. The network provider is configured to forward to a remote on failure, and as soon as that happens, gnome-calls changes and says the modem is fine and available. So, after the phone wakes up, between light the screen and start gnome-calls the process goes sideways, sometimes. The following is quote from a person who was middle aged (40?) when I was young. Which was a long time ago, lol > The bad thing about hardware is that it sometimes works and it sometimes doesn't. > The good thing about software is that it's consistent: it always does not work, and it always does not work in exactly the same way. Thanks to all who contribute HTH LF
11-23-2020, 03:19 AM
(11-11-2020, 10:57 AM)Lousy Fisherman Wrote: Dare I hope? Mobian October 5th, apt-get update/upgrade November 10, 2300UTC. (11-11-2020, 11:55 PM)Lousy Fisherman Wrote: Thank you for the warning, I have been doing more testing. WIFI and Bluetooth off at the software level. Mobian apt updated to last nightWhen USB is connected screen suspend is flaky, When the screen does not suspend properly gnome-calls responds 100% of the time. There is no mobile data at any time, even immediately after boot Hi LF, I believe I'm currently looking for a similar setup as yours. We're prepared to buy a few PinePhones as long as we can get VoIP working in some manner. We don't want to use the internal quectel card but will connect to the internet via wifi or other possible means that I may be unaware of (not bluetooth as its not secure). Just wanted to double check that you're currently using Mobian and what app for VOIP? Also what is your external PTSN telephone number provider? I've had great success with twilio and Zoiper app on android and ios but want to get away from closed source systems. Do you think I could still make Twilio work or do you recommend another provider? Thank you
11-23-2020, 10:17 AM
(11-23-2020, 03:19 AM)JuniperFury Wrote: Hi LF, I believe I'm currently looking for a similar setup as yours. We're prepared to buy a few PinePhones as long as we can get VoIP working in some manner. We don't want to use the internal quectel card but will connect to the internet via wifi or other possible means that I may be unaware of (not bluetooth as its not secure). Just wanted to double check that you're currently using Mobian and what app for VOIP? Also what is your external PTSN telephone number provider? I've had great success with twilio and Zoiper app on android and ios but want to get away from closed source systems. Do you think I could still make Twilio work or do you recommend another provider?Arch, Mobian and Manjaro are all functional. There are multiple VOIP apps in the repos. I built a custom version of Twinkle, but all of the apps should work. Multiple PSTN providers, both telecom companies and SIP. What you get working is going to depend on how well you understand linux and the various systems you interact with. Currently using Arch 2020112, pacman -Syu 2020-11-21, as my one and only phone. See Arch thread for details HTH LF
11-24-2020, 10:13 PM
(11-23-2020, 10:17 AM)Lousy Fisherman Wrote: Arch, Mobian and Manjaro are all functional. There are multiple VOIP apps in the repos. I built a custom version of Twinkle, but all of the apps should work. Thank you for the info! Decided we'll definitely buy a few PinePhones and even some Rock64s.
11-25-2020, 06:59 PM
@JuniperFury
If you purchase the Convergence Edition package phone, you can use the ethernet connection via the "Docking Bar" to connect to the internet without using wifi, should you choose to do so.
LINUX = CHOICES
**BCnAZ** Donate to $upport your favorite OS Team
11-26-2020, 10:56 PM
(11-25-2020, 06:59 PM)bcnaz Wrote: @JuniperFury Very good to know! I'd rather not be forced to use wifi all the time. Will absolutely get the docking bar. |
| Article: (Clickable) Call Graph for Apache NuttX Real-Time Operating System | lupyuen | 0 | 2,653 |
03-04-2023, 10:39 PM Last Post: lupyuen |
| Video: Apache NuttX Real-Time Operating System for PinePhone | lupyuen | 0 | 2,956 |
02-07-2023, 07:35 PM Last Post: lupyuen |
| Help wanted: location of calls and chatty data files | dukla2000 | 3 | 8,798 |
06-13-2022, 02:01 PM Last Post: israel |
| Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted! | kop316 | 201 | 344,307 |
03-24-2022, 03:16 AM Last Post: as365n4 |
| First time pine phone user | Matt73 | 3 | 6,190 |
03-10-2022, 02:04 AM Last Post: Matt73 |
| Response time | generaluser | 0 | 2,343 |
10-06-2021, 06:52 PM Last Post: generaluser |
