emmc doesnt show up on pc using jumpdrive
Hey guys, received my Pinephone a couple of days ago and decided to flash Mobian to the emmc, but encountered
an issue.
I followed these guides:
https://www.youtube.com/watch?v=seLfbIIAycc
https://www.youtube.com/watch?v=kw3FFz7o-MU
They both use Jumpdrive and Etcher to flash the image and it seemed like the easiest way to go about the installation.
I've flashed Jumpdrive to an SD card I had lying around and managed to boot into it, but after I connected the Pinephone
through a cable to the PC, the emmc did not show up on Etcher like it did in both of these videos.
I tried installing a Manjaro VM to see if it's a Windows 10 problem but the phone still doesnt show up.
Any idea what I'm doing wrong?
(11-06-2020, 02:14 PM)Bruhmoment Wrote: Hey guys, received my Pinephone a couple of days ago and decided to flash Mobian to the emmc, but encountered
an issue.
Did you get anywhere with this?
Maybe try a different SD card, or a different cable.
have you tried unplugging the phone , and then plugging it back in?
Balena Etcher + Jumpdrive 0.6 + Windows 10 simply does not work for me.
I recommend using Win32DiskImager instead. On my machine the eMMC shows up as drives G and H. I have had success flashing by selecting drive G as the destination.
It might also be a good idea to disable automount in Diskpart. This is particularly important for distros that create many partitions (e.g. UBPorts).
Did you use the correct version of jump drive? There's three versions - one for 2g, 3g, and pinetab. They are not cross compatable.
  New Install, apps start but don't show up on screen?! RT3 2 2,806 07-18-2025, 07:56 PM
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 9,915 11-22-2023, 11:46 AM
Last Post: aLoop100o
  Lot of issues after flashing mobian to emmc with tow-boot benedikt55 5 7,268 08-30-2022, 01:14 PM
Last Post: benedikt55
  spontaneous reboots in jumpdrive mode flynx 0 2,041 08-23-2022, 03:48 PM
Last Post: flynx
  DDing mobian to emmc or microSD not starting... Mr.Berzerk 2 3,625 08-05-2022, 06:09 PM
Last Post: mark1250
  More weirdness when booting from eMMC Zebulon Walton 2 3,809 10-27-2021, 07:06 PM
  Modem suddenly not enabled when booting from eMMC Zebulon Walton 3 5,658 10-23-2021, 01:55 PM
  How to flash modebian to emmc maybl8 4 8,578 10-20-2020, 10:26 AM
Last Post: dukla2000
