How do I install packages?
Hi All!
I tried to install packages using "sudo apk add xxx" or simply to check the upgrades via "sudo apk upgrade". Nothing really works...
All I get is
ERROR: unable to select packages:
cmd: convert (virtual):
provided by:imagemagick
required by: megapixels ...
What do I do wrong?
Thank you!
Check out this package management wiki for Alpine Linux. All of it should apply to PMOS.
you need to add the imagemagick package before doing anything:
sudo (apk add imagemagick; apk upgrade)
(11-11-2020, 06:05 PM)hiimtye Wrote: you need to add the imagemagick package before doing anything:
Thank you, worked out fine. Smile
  Fresh install pmos+phosh does not boot user641 1 3,716 10-08-2023, 04:04 AM
Last Post: user641
  Install 9999 packages AndyM 0 3,363 07-24-2023, 01:07 AM
Last Post: AndyM
  Can't install powersupply user641 0 2,837 07-18-2023, 08:09 AM
Last Post: user641
  Trying to install Mousai AndyM 0 3,113 06-10-2023, 08:25 AM
Last Post: AndyM
  how to install updates? someGermanGuy 2 5,020 04-26-2022, 12:48 PM
Last Post: someGermanGuy
  Current version of packages user641 3 6,595 01-03-2022, 12:02 PM
Last Post: kqlnut
  How to install software AndyM 8 15,168 11-14-2021, 01:08 AM
Last Post: AndyM
  No shortcuts on homescreen after installing packages jojuma 0 2,864 04-26-2021, 04:08 PM
Last Post: jojuma
  packages on Alpine hiimtye 2 6,848 11-14-2020, 05:19 PM
Last Post: hiimtye
  Unsure how to install, help needed GloriousCoffee 8 20,089 09-01-2020, 10:55 PM
Last Post: bitnick
