Does etcher work on manjaro arm if you use pacman? Will it build the package? I noticed it has a Debian extension.
Write SD cards with Etcher for Pinebook Pro
Just figured from a source that you could build the etcher-git package from aur repository on manjaro in case others are wondering as well. It has been modified for aarch64.
::package failed to build... Was recommended to use *imagewrite* as a substitute for manjaro.
10-05-2020, 08:11 AM
(09-28-2020, 05:20 AM)Mangled Wrote: Just figured from a source that you could build the etcher-git package from aur repository on manjaro in case others are wondering as well. It has been modified for aarch64.Imagewriter was recommended, however after installing it and testing the USB stick, it did not work. I found another compatible program for aarch64 called: fedora media writer. I personally tested this one and it works great.
11-01-2020, 03:05 PM
(10-05-2020, 08:11 AM)Mangled Wrote:I had my hopes up about flashing OS's to SD cards using PBP... I have manjaro but it looks like we can't get Etcher to run on it yet? I've installed imagewriter, but it looks like that's only for USB's and not SD cards... I'd test it out if I had a spare SD card, but I'm all out, for now. I'm just starting out trying all this stuff out! I'm interested to see if anybody makes any progress doing this on manjaro.(09-28-2020, 05:20 AM)Mangled Wrote: Just figured from a source that you could build the etcher-git package from aur repository on manjaro in case others are wondering as well. It has been modified for aarch64.Imagewriter was recommended, however after installing it and testing the USB stick, it did not work.
11-01-2020, 03:59 PM
(11-01-2020, 03:05 PM)11Eleven Wrote:(10-05-2020, 08:11 AM)Mangled Wrote:I had my hopes up about flashing OS's to SD cards using PBP... I have manjaro but it looks like we can't get Etcher to run on it yet? I've installed imagewriter, but it looks like that's only for USB's and not SD cards... I'd test it out if I had a spare SD card, but I'm all out, for now. I'm just starting out trying all this stuff out! I'm interested to see if anybody makes any progress doing this on manjaro.(09-28-2020, 05:20 AM)Mangled Wrote: Just figured from a source that you could build the etcher-git package from aur repository on manjaro in case others are wondering as well. It has been modified for aarch64.Imagewriter was recommended, however after installing it and testing the USB stick, it did not work. If you use a usb to sd card adapter, your computer will see a usb drive.
11-01-2020, 04:13 PM
11-26-2020, 07:35 PM
(11-25-2019, 12:48 AM)linusfargo Wrote:(11-23-2019, 05:14 PM)TDC_PBP Wrote: This is really complicated, but is it possible to boot from microsd on the PBP, install Etcher, and then flash the EMMC inside the Pinebook Pro with it? I am relatively new to Linux and would prefer to use the Etcher UI instead of the command-line DD command. Thanks!
03-19-2021, 12:52 AM
(05-30-2020, 06:03 PM)ALBNC1974 Wrote: Have you tried warm-booting to the sd card? You can now download the U-Boot image onto your target's boot storage device using the appropriate procedure. If you already have U-Boot or one of its ancestors (PPCBoot or ARMBoot) installed on your target, you can use the installed copy to update U-Boot to a new version, as we shall see in Section 9.5.10. If you have another bootloader installed, follow the procedures described in that bootloader's documentation for updating bootloaders. Finally, if you have no bootloader whatsoever installed on your target, you need to use a hardware programming device, such as a flash programmer or a BDM debugger, to copy U-Boot to your target. |
| Pinebook Pro Recovery with Void Linux (xbps) | bds | 4 | 6,390 |
09-13-2024, 07:01 PM Last Post: bds |
| [GUIDE] ArchLinuxARM on Pinebook Pro | hku2 | 10 | 30,605 |
12-25-2020, 05:44 AM Last Post: boteium |
| Program SPI NOR Flash on Pinebook Pro with u-boot on micro SD Card | hmuller | 0 | 6,441 |
09-21-2020, 10:02 AM Last Post: hmuller |
| Installing Docker on Pinebook Pro - update 1/18/20 | SuperXkoodA | 4 | 12,276 |
03-24-2020, 03:19 PM Last Post: chaoskampf |
| Swaywm on Pinebook Pro | anjanmomi | 10 | 22,795 |
02-06-2020, 11:47 AM Last Post: xmixahlx |
| Quick Guide to installing Ubuntu Unity on your Pinebook Pro | andybleaden@gmail.com | 19 | 39,799 |
02-03-2020, 11:17 AM Last Post: MIchael |
| Installing Wine i386 on Pinebook Pro | wrzomar | 0 | 4,887 |
01-31-2020, 03:52 PM Last Post: wrzomar |
| Hardening your Pinebook Pro software | Arwen | 4 | 11,725 |
12-11-2019, 09:53 AM Last Post: hdk |
