10-22-2020, 03:48 AM (This post was last modified: 10-22-2020, 03:50 AM by peperjohnny.)
(10-21-2020, 02:11 PM)andybleaden@gmail.com Wrote: Well
Bluetooth to headphones didn't work
Nor to a speaker
Sound is now persistent
Apps Vs browser confirmation like with Twitter is bust
Could do with landscape mode but terminal landscape works!
Questions are
How to field bugs
Post solutions
Upgrade
How close is pinephone development to pinetab?
The situation is improving rapidly upstream. Adam Pigg has made some improvements to the builds and you're able to build it now from the flash-it script once again.
I'll ask where we'd like to have it filed best and will update later on.
File away here https://github.com/sailfish-on-dontbeevi...tab/issues
(10-22-2020, 09:54 AM)andybleaden@gmail.com Wrote: I was wondering how the best way would be to update any of the changes you make upstream?
Also quick question - I am really enjoying using this. Feels good and promising after a few days
Few issues (as we know BT/Keyboard etc) BUT
If I wanted to stick this on the EMMC - would I do this using jumpdrive do you think? (all my own risk etc etc )
You may get some of the updates with a
zypper update
Jumpdrive should do fine. The current version doesn't display anything on the tab, but it should be visible on your PC.
all really helpful, will try all suggestions when I have a mo and happy to help report issues if it helps you all
Have had a try at compiling this myself from scratch and not sure I am able to.
I use Ubuntu on my desktop and was coming up with all sorts of errors as this is an Arch build I take it. Also tried on my Pinebook pro (Manjaro ) but again similar errors.
So questions:
Should it be possible to do on an Ubuntu pc? ( I have used it for long enough to have built drivers via the command line before using make etc)
Should it be easier on the Manjaro machine
If so I am happy to build a weekly build and host (different Alphas) so we can keep this moving. I am afraid I am not so good at squashing bugs but if I can compile and build an image and then back that up as an .img I am more than willing to do so to ease the burden.
Why?? Because out of the builds I have used so far on the Pinetab this is the nicest - even as it is better for me to use and more enjoyable as it is even with no keyboard (physical) or Bluetooth (pity)
Hopefully not treading on anyones toes but happy to muck in and help if I can
(10-30-2020, 02:53 AM)andybleaden@gmail.com Wrote: Have had a try at compiling this myself from scratch and not sure I am able to.
So questions:
This should work under Ubuntu too. There's nothing arch specific with this build as far as I know.
Currently the keyboard works in the dev builds, but screen is broken. Probably because of the config used for the kernel build. We might be able to sort this out this weekend, with which one could use the flash-it script once more.
Once 3.4 is available on OBS it will be included too I think.
If you tell me the specific errors, I'll try to help you as much as I'm able. I'll update my kernel build for starters to include the latest changes, that may help a bit already.
So questions:
OK happy to repeat this and post up the errors I get
Like I said it is more likely Ubuntu errors than errors in your build
Lets see
In the meantime I will wait perhaps until you update it
