Backlight issue fix?
There is finally a new section in the wiki concerning Pinephone hardware edition 1.2a (postmarketOS CE). It says that two backlight issues are still present in 1.2a; the second one will probably be fixed in the Manjaro CE version. However, nothing is said about the first one. This is a pretty serious issue: it makes Pinephone barely usable in very low lightning conditions due to the blinking of its backlight. Are there plans to fix it for the Manjaro CE?
Would like to know too.
There is now a section in the wiki Pinephone hardware edition 1.2b (Manjaro CE).
It seems the main backlight issue has not been fixed. Bad news. Thinking about cancelling my order of Manjaro...
I'd love to take advantage of the discounted 1.2b board, but I'm put off by the backlight issue as well Undecided
In actual use, in dark rooms I have not noticed any problems with the screen.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
@bcnaz I believe the issues is twofold: how "low" the brightness can go, and PWM strobing.
(11-09-2020, 02:15 AM)jed Wrote: @bcnaz I believe the issues is twofold: how "low" the brightness can go, and PWM strobing.
PWM is only used to generate reference voltage for the stable current source. Backlight brightness is not done by PWM strobing of the backlight LEDs themselves.
Unfortunately the reference voltage for PWM GPIO pin is not completely stable. Any variation in that voltage is quite visible on the LED bightness, especially since at low brightness backlight LEDs are operating in the knee of their V-I characteristic, and are very sensitive to any change in current of the constant current source regulated by that PWM.
The further away from the knee, the less this is an issue.
my website: https://xnux.eu
Thanks for the clarification @megous Smile
@megous commented on that:
I'm not aware of any effort to fix that. It's already reasonably non-flickery thanks to other fixes, since that paragraph was written.
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 5,631 03-20-2023, 12:54 AM
Last Post: bcoyle
Bug DESIGN ISSUE? Speaker + vibration motor broke for the 2nd time e1337 11 13,620 01-26-2023, 10:11 PM
Last Post: AnAbolitionist
  Odd Issue CzarD0mn 3 5,686 06-12-2022, 02:36 PM
Last Post: alaraajavamma
  Pinephone convergence dock issue. Joshua 2 4,919 12-27-2021, 03:11 PM
Last Post: nelstomlinson
  Pine Phone Battery Issue vslash 21 37,304 08-09-2021, 07:35 AM
Last Post: mouffa
  Modem SMS issue(s) Helium75 3 7,724 08-03-2021, 06:30 PM
Last Post: bcnaz
  Hardware fix for the screen backlight flicker dsimic 4 12,560 05-03-2021, 04:43 PM
Last Post: dsimic
  Screen touch issue docofkult 2 5,962 11-17-2020, 01:25 AM
Last Post: docofkult
  New UBports edition - black screen (backlight) only BBreeziN 11 23,442 08-10-2020, 05:17 AM
Last Post: wibble
Sad Crashes in every OS - Hardware-issue? rakor 4 10,533 06-22-2020, 09:20 AM
Last Post: Nooblife
