Screen touch issue
So even though I didn't really play much with the Braveheart model, I decided to get the upgraded board. After the installation I started noticing that the left side of the screen acts a bit strange to touch events. I can't recall having this issue prior to the board swap but now it is the same for both the old and the new board.
I have been running Manjaro and first noticed that something was a miss when I could not tab the leftmost keys on the virtual keyboard. However, events where still detected but for the key to the right. I'm not sure what to think as the rest of the screen are accurately detected so it doesn't seem like a calibration issue?
I have tried reseating the cables and also tried postmarketOS where the issue was reproducible. This of course will not rule out a software issue but then I would believe that I would be more widely reported?
Have anyone experienced the same or have any ideas to how to fix it?
I think you've already tried everything I would have suggested. Given it's now happening with both boards and more than one OS it seems likely to be a hardware issue with the touchscreen. Can you see any damage on the FPC or flexy? I hope someone else has some better news for you.
Hi thanks for answering.
It seems like it is the flex cable next to the headphone jack that is the touch panel controller. I will make another attempt at reseating the cable but otherwise it likely got damaged during the first swap.
Pine64 sells replacements but I'm not sure it will be worth it with the import taxes unless the also start selling spare parts from there EU warehouse.
Sendt fra min ONEPLUS A6003 med Tapatalk
  Screen dying already? marcih 156 301,845 06-12-2025, 06:18 AM
Last Post: mikeb
  Screen Replacement Instructions erikkugel 5 11,929 02-24-2025, 06:55 AM
Last Post: anonymous
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 2,023 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 6,595 10-12-2023, 01:03 PM
Last Post: robthebold
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 5,426 03-20-2023, 12:54 AM
Last Post: bcoyle
Bug DESIGN ISSUE? Speaker + vibration motor broke for the 2nd time e1337 11 13,206 01-26-2023, 10:11 PM
Last Post: AnAbolitionist
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 8,546 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 4,646 07-03-2022, 06:27 AM
Last Post: Avisando
  Odd Issue CzarD0mn 3 5,497 06-12-2022, 02:36 PM
Last Post: alaraajavamma
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 9,076 03-08-2022, 12:25 PM
Last Post: jopple
