Sound defaults to Headset
Bug
The fix is listed in this reply.
Is there any way to prevent the Sound Output and Input resetting to using the Headset?
In earlier builds, the Sound would default to the Internal speaker and microphone, and route audio through the earpiece when making a call.
After an indeterminate upgrade, Output and Input persistently reset to the Headset - despite being changed in the Sound (Settings) menu, or pavucontrol.
Check out this discussion about checking and setting default devices in Pulseaudio.
Related question: were your headphones plugged in while this upgrade took place?
@ThrillGates Thanks.
I'm using a Braveheart edition; I've only used headphones a couple of times for testing purposes, removing the jack immediately afterwards. So, probably not.
(10-18-2020, 01:00 PM)jed Wrote: @ThrillGates Thanks.
I have the CE UBports edition. I never plug headphones and also it is always set at the headset. Very annoying because even if you changes, it goes back to headset. So no way to have a conversation the mic and audio are set to headphones.
@jed have you fixed? does @ThrillGates link works? I will try later.
Thanks for the bump @natasha , I've been putting this off... PulseAudio is the bane of GNU/Linux.
The Internal and Headset ports are available via a single sink and source. The Headset has priority, you can evaluate this using pactl:
pactl list sources
pactl list sinks
Installing the 5.8 kernel solves this issue (comment).
sudo apt update && sudo apt install linux-image-5.8-sunxi64
sudo reboot
Headset now correctly manifests as 'Headset (Unplugged)'. The Internal speaker and Internal microphone are now the default.
Priorities are unchanged, meaning the active source and sink ports can change when a Headset is plugged in.
(10-21-2020, 03:44 PM)jed Wrote: Thanks for the bump @natasha , I've been putting this off... PulseAudio is the bane of GNU/Linux.
pactl list sources
pactl list sinks
sudo reboot
I was realizing that the headset problem was solved a few updates ago, but couldn't find the exact update that fixed it.
now 'uname -a' gets me: Linux mobian 5.8-sunxi64 #6 SMP Sun Oct 18 12:56:04 UTC 2020 aarch64 GNU/Linux
for a while in the Setting - Output Device, the Test doesn't say "Front Right", and "Front Left" any more. Instead, it would have one of the 4 sounds for both channel. So then  just now, the 2nd time I hit test, and the woman's voice is back saying Front Right, Front Left.  The default is on the Internal mic.  Incoming calls have been working fine. No complaint about voice quality.
I'm glad to read the newer kernel is working for you too @HLing Smile
pactl list sources
pactl list sinks
sudo reboot
yes, it fixed it!
thanks!
(10-21-2020, 05:18 PM)jed Wrote: I'm glad to read the newer kernel is working for you too @HLing Smile
@"jed" , Thanks for clearing up the mystery.  I really should keep a  Mobian calendar so I know what happened when, and how something got fixed...
Credit to Parthiv Seetharaman who opened the issue and closed it with the above fix.
I'll be keeping a closer eye on the Mobian issue tracker from now on! Blush
  Sound : notifications freelectro 6 8,211 06-07-2023, 01:03 AM
Last Post: freelectro
Exclamation No sound anonymous 22 25,836 11-08-2022, 09:07 AM
Last Post: dante404
  My sound went away with calls... Not sure what happened. How can i fix it? usourypg3i 4 6,463 02-18-2022, 08:54 AM
Last Post: battlegarden
  Lost all sound Dinosaur1946 0 2,815 01-27-2022, 07:34 PM
Last Post: Dinosaur1946
  Sound design for Mobian S.E.B 4 6,872 12-27-2021, 05:40 AM
Last Post: Anna
  No Sound After Reboots LMalilil 1 4,739 09-23-2020, 06:14 AM
Last Post: bobblestiltskin
  earpiece sound setting Gobelin 3 6,247 08-13-2020, 01:46 PM
Last Post: Gobelin
