Pinebook Pro has become dead, no lights
Hi people
I've had a PBP working successfully for a month or so. But now it's dead.
It's sat in an inmoving position, connected to the mains with the barrel charger which I switch on from time to time to top up the battery. It's mostly used for flashing to my pinephone so it's not been used heavily, I also have tried a few OS's so it has been booting from multiple SD cards and the emmc (from original Manjaro) successfully.
Yesterday I flashed opensuse to the emmc (booted and rebooted a few times) and decided it wasn't for me so I flashed Manjaro again but after I tried to reboot it crashed so I had to force shutdown with 10s hold on power button. After that it failed to start up (no lights on front but charger is lit red when plugged in).
After leaving it for an hour or so it started, but after a reboot it went back to dead. And next day that's how it still is.
As it's not been moving it's unlikely to be a loose cable inside so I hesitate to take the back cover off.
Are there any known issues that may help me? Could repeated plugging of mains/SD/USB cause this?
I'd have to guess the battery ran down. There's another thread here where someone used a USB-C charger to bring up the battery high enough to where the normal charger would work.
(10-16-2020, 03:21 AM)KC9UDX Wrote: I'd have to guess the battery ran down.  There's another thread here where someone used a USB-C charger to bring up the battery high enough to where the normal charger would work.
Oops, I missed out that KDE was displaying more than half battery when it stopped.
Anyway, thanks, I'm trying that now.
How long is the waranty? can you use it?
(10-16-2020, 08:39 AM)daniel Wrote: How long is the waranty? can you use it?
TBH I never looked at warranty cos its from so far away (I'm in UK). I've got another laptop to use so I'll have to take this one apart if no-one has any further ideas. It's been on usbc charging for 5 or so hours and it's still dead.
  Selling Pinebook Pro, PineNote and PineTab-V arw 2 520 08-06-2026, 12:10 PM
Last Post: arw
  Could Someone Give Advice on Optimising Pinebook Pro for Software Development? Octaviah 0 2,461 08-23-2024, 12:45 PM
Last Post: Octaviah
  [Pinebook Pro] Where to buy a new TFT and how to replace it? openbsd98324 2 3,328 07-23-2024, 07:14 AM
  Pinebook Pro with RK3588? tantamount 28 27,922 07-13-2023, 04:06 PM
  The power of the Star64 vs Pinebook Pro/RockPro64 Starfall 1 3,543 04-17-2023, 05:00 AM
Last Post: lkoini
  PinePower USB-C ports dead nbxmike 1 3,572 01-31-2023, 03:45 PM
Last Post: fxc
  PinePower Desktop USB-C port dead qeek 3 5,365 08-29-2022, 12:33 AM
Last Post: gravedigger
  Could an arm based pine 64 smaller than expected to go with the pinebook zanewiller 1 3,795 04-16-2022, 07:17 AM
Last Post: jiyong
  Could an arm based pine 64 smaller than normal to go with the pinebook zanewiller 0 3,298 04-06-2022, 01:30 AM
Last Post: zanewiller
Star Very Lightly Used PineBook Pro ragnarlothbrok64 4 6,687 01-21-2022, 02:36 PM
Last Post: sascha
