Visible or viewable screen/image scale
I apologize.  I am sure this has been dealt with already, but I don't know what search terms to use.
Please see the attachment for an visual explanation of my question/issue.
In my own terms, I am unable to view the entire Android image on either of my 1080P TV screens.  The image runs over into unviewable space.  I have been through the Android settings, but I haven't found anything to work toward solving this issue.
Any ideas?
(04-30-2016, 09:57 PM)NondescriptMember Wrote: I apologize.  I am sure this has been dealt with already, but I don't know what search terms to use.
Any ideas?
This is TV legacy overscan issue. We currently work on new Android build that able to scale down full image to TV overscan windows and hopefully this build will release in two weeks time. The best way is check your TV setup and set to full screen mode.
Any ideas?
Wow 2 weeks? At this rate we wont have this thing fully functional before January 2017. Are they addressing the limited resolution issue at the same time, i.e. will there be a way to run at 720p and other resolutions?!?
Any ideas?
Thank you for the reply.
I also have the same issue with one of the TVs I am using my pine on. I also had the same issue connecting a computer running Ubuntu to said TV. Could not find options on the TV to correct the screen view, but I fixed it within Linux using the xrandr utility. Android is based off linux, maybe there is a way to use xrandr on a pine running android as a temporary fix until the new image is released.
Further to tllim's comment - some TVs/Monitors have scaling capabilities built into that can be found in OSD. It is usually called something like: Just Scan, Full Pixel or 1:1 Pixel Ratio. See if you TV/Monitor gives you this option.
Any ideas?
No need to wait till January 2017. I am currently finalize the Andoid image release, still one more small issue and good to release on early next week.
Hi tllim
Are you also working on other resolutions,  apart from 1080p @60hz?
(05-07-2016, 02:12 AM)uberal Wrote: Hi tllim
One build will be release today that support 720P. However, the boot up screen still in 1080p even the setting change to 720p, but the HDMI willl switch to 1080P when ether Android home screen. We will release on next build that set boot up screen to 720p.
No one supporting 1440x900??
  screen rotating Miguelito71 0 4,551 07-29-2019, 12:48 AM
Last Post: Miguelito71
  Youtube TV experience/ screen resolution issues gubaguba 0 3,058 02-22-2018, 09:12 AM
Last Post: gubaguba
  Android 6.0 How to turn the screen back on modsbyus 4 8,284 11-28-2017, 01:03 PM
Last Post: modsbyus
  Reducing Android Image download size. KPhillisJr 4 11,796 08-21-2017, 04:48 AM
Last Post: winstongel
  Is there an android tv image out there where I can install netflix? eclay 2 8,554 07-18-2017, 08:49 AM
Last Post: eclay
  Orange Screen All versions of Android TV XsoundXhoundX 17 32,585 05-19-2017, 01:27 AM
Last Post: Israeldelamo
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 32,386 05-05-2017, 01:50 AM
Last Post: Quezbeme
  android image & sd card size problems tomarneson 11 24,965 01-24-2017, 05:31 AM
Last Post: ayufan
  Screen wakeup Danja 17 32,436 12-22-2016, 05:30 AM
Last Post: Workaholic
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 34,137 10-29-2016, 04:31 AM
Last Post: joe
