Ubuntu 20.10 beta
>Or is there another Ubuntu...?
look at /etc/apt/sources.list
elementary, q4os, ....
(10-08-2020, 09:24 AM)wdt Wrote: >Or is there another Ubuntu...?
I was using the ayufan Ubuntu 20.04. Then upgraded to 20.10.
https://github.com/ayufan-rock64/linux-build/releases
Again, that is for rock64,,, that is NOT a pinebookpro, that is what you have, right?
For that matter, rock64 is a different cpu, rk3328, rockpro64 has same cpu(as pbp) rk3399
rock64 will NOT work on a pbp
On this forum , rock64 is 6 sections down, rockpro is at bottom
Went to wiki
I see if you click heading that it takes you to a list of images, pinebookpro is in that list
I assume that is the image you got
(10-08-2020, 04:50 PM)wdt Wrote: Again, that is for rock64,,, that is NOT a pinebookpro, that is what you have, right?
Went to wiki
The PBP images are under assets, that link is the one in the wiki.  It's either link that page or direct-link the image, I assume.
Does the Ubuntu Mate image work for 20.04?  I went with the Bionic Mate image when I got my PBP because I prefer Mate but in the last few days I'm getting some messages that an upgrade to 20.04 LTS is available on my PBP itself.  Doesn't do anything when I try to start the upgrade, but I hadn't seen that before.
Ubuntu Mate is the default and works well too.
Went to wiki
Correct, the image for pinebook pro is in that list. The images work fine on SD cards but am having trouble with making the emmc boot with Ubuntu. I have another conversation going if you want to attempt it as well.
https://forum.pine64.org/showthread.php?...6#pid80326
(10-06-2020, 01:33 AM)Wizzard Wrote: I upgraded too and it went smooth and it works well, even better than on my x86 laptop (it has a problem with sound)
Kernel stayed the same, GPU acceleration and sound works, no problem.
There was some additional keyboard switcher in the tray, so I just uninstalled all "ibus*" packages and rebooted.
I just tried to play a clip from YouTube and noticed the sound doesn't work. Does it work for you? How did you get it working? I did notice pulseaudio was installed but didn't see it in sound settings.
Yes, it works. I just had KDE installed and upgraded to 20.10. It is funny, cause I cannot get sound working on my x86 PC.
#19
(10-10-2020, 02:55 PM)Wizzard Wrote: Yes, it works. I just had KDE installed and upgraded to 20.10. It is funny, cause I cannot get sound working on my x86 PC.
I flashed Ubuntu on my emmc drive by removing the case and taking out the emmc. I think by opening the case, I may have pulled to hard on the speaker wires as the speakers are taped onto the cover plate. I will have to check the connection. I think that may be my issue.
#20
Can you just check if you have some real audio device present? If you have something different from null output, it may be your case, some hardware issue.
  After update in Ubuntu bionic mate system crashed Wawe 2 7,342 04-18-2021, 04:52 AM
Last Post: Wawe
  Ubuntu Installation on PBP narinderpal10 5 12,288 12-18-2020, 12:22 PM
Last Post: narinderpal10
  Ubuntu MATE 18.04 Can't boot after update hankg 2 8,723 12-15-2020, 01:53 AM
Last Post: BryanF
  Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound Syonyk 17 33,493 11-19-2020, 03:16 AM
Last Post: FeMike
  Ubuntu 20.10 bastafari 6 12,802 10-27-2020, 10:16 AM
Last Post: Mangled
  How does one get working deep/S3 sleep with Ubuntu Focal/5.7 mainline kernel? Syonyk 7 16,344 10-26-2020, 02:03 PM
Last Post: edward
  ANSI keyboard fix for ubuntu Mangled 0 3,379 10-05-2020, 02:15 PM
Last Post: Mangled
  Debian (or ubuntu) on a micro sd card (pinebook pro) pine76 28 65,062 09-06-2020, 08:20 AM
Last Post: pine76
  Ubuntu for RockPro64 dndeokar 1 5,490 08-14-2020, 06:42 AM
  Ayufan's Ubuntu Focal Gnome (20.04) mlentink 24 45,631 07-02-2020, 11:04 AM
Last Post: mlentink
