GloDroid (Android-13)
#41
Very cool, thank you!
Are the RIL and binaries provided by Quectel officially?
(09-18-2020, 12:36 AM)rsglobal Wrote: Very cool, thank you!
Yes they are provided by Quectel officially.
I got it here:
https://forums.quectel.com/t/ec25-e-andr...ers/2885/6
https://forums.quectel.com/t/ril-library...el/5178/15
In my last post I forgot to say the gps test app is not official from Quectel.
https://github.com/barbeau/gpstest
https://f-droid.org/de/packages/com.andr....osmdroid/
(09-17-2020, 10:21 AM)bauner Wrote: I got the RIL + GPS partially working in glodroid 0.4
It needs much more work + cleanups to get it fully working and not break
other glodrod devices
    Make and receive calls are working
    Audio/mic in call are not working
    SMS/MMS are not working
    Mobile data is not working
    GPS fix will need ~20 min
Test Image:
https://androidfilehost.com/?fid=8889791610682939941
The fastboot file had some permission issue so swapped one in from a previous build. Not sure if that contributed to the corruption message on first boot but it did a factory erase (after entering password 1234) and rebooted fine apart from a popup saying "internal problem with device".
Haven't had time to check gps but calls connect and button tones can be sent from the pinephone end - Great work!  Smile
wow, amazing progress! so we could have a working android image this year! great stuff
I'm trying to build Glodroid on my Ubuntu laptop. When I get the the make images step it starts but it slowing locks up the machine and then the screen blanks. I assume I've got build processes running wild and it's running out of some resource. Is there something I can do to adjust this or a resource that would provide some clues?
(09-22-2020, 05:51 PM)Beattie Wrote: I'm trying to build Glodroid on my Ubuntu laptop. When I get the the make images step it starts but it slowing locks up the machine and then the screen blanks.
I'd guess you're running out of memory (add more swap storage?) but there are ready-made builds here - version 0.5 just became available.
@bauner ,
Do you have in plans to contribute your changes to GD?
May I offer any help from my side?
(09-23-2020, 11:35 AM)nas Wrote: I'd guess you're running out of memory (add more swap storage?) but there are ready-made builds here - version 0.5 just became available.
The links on the main page still point to 0.1  https://glodroid.github.io/
(09-23-2020, 02:35 PM)rsglobal Wrote: @bauner ,
Currently I don't know how to get incall audio working.
If you want feel free to use any part of my changes and implement it yourself in your current GloDroid tree
  GloDroid (Android-14) GaryM 1 5,454 04-17-2024, 08:39 AM
Last Post: GaryM
Tongue Android Auto on Pinephone via Waydroid: a pipe dream? slondr 1 4,671 11-06-2022, 01:46 PM
Last Post: wibble
  difference between android and linux? vanja 3 5,022 09-16-2022, 07:43 PM
Last Post: TRS-80
  Android and Google Play Store on a PinePhone? Solra Bizna 22 57,444 11-01-2021, 07:11 AM
Last Post: digitalmouse
  Easiest way to use Android applications on Pinephone esud 4 14,485 06-21-2021, 04:52 AM
Last Post: vanja
  Remote connection from Linux Mobile to unrooted Android? (surely very useful?!) 4w7gvrvsjcyvd 0 3,085 01-30-2021, 06:48 PM
Last Post: 4w7gvrvsjcyvd
  pine phone came with android? andrewiassur 1 4,909 04-11-2020, 02:06 PM
Last Post: fire219
