My Daily QA - 2020-09-08
Be aware, these tests are being executed using an out-of-box testing methodology. All tests are preformed with minimal interaction/setup of devices outside of: OS imaging/updating,  SIM installation, Wifi Configuration,  and Power Cycling the devices.
Results: mobian/09-08-2020-TMobile.html
               mobian/09-08-2020-Verizon.html
Conclusion: OS is not Ready for pinephone to be daily driver.
Notes: The Microphone is still really sensitive. The audio out quality is suffering. Camera still super laggy. I've notice that the apps are taking longer to load. The Camera and Firefox are taking 15 seconds+ to load. I ran another longevity test, When the phone goes to sleep it disconnects from wifi and cell data. Texts are no longer getting through when this happens.
Are you using the nightly & is that from an sd card.?
Thanks for your effort, time, and sharing.
(09-08-2020, 08:24 PM)bcnaz Wrote: Are you using the nightly & is that from an sd card.?
Now I am only doing apt update/upgrade. Should be the same as reflashing? Is any difference?
Yes to both. The nightly and using an sd card
Not certain I understand clearly, but when you download and use the 'status' release that is relatively a 'safe' edition.
While the nightly is sort of 'cutting edge'.
 So if you do the updates are those 'cutting edge' or safe  updates ?
or  do you need to open the development channel for cutting edge updates.?
(09-08-2020, 04:54 PM)AmazingNutria Wrote: Be aware, these tests are being executed using an out-of-box testing methodology. All tests are preformed with minimal interaction/setup of devices outside of: OS imaging/updating,  SIM installation, Wifi Configuration,  and Power Cycling the devices.
Results: mobian/09-08-2020-TMobile.html[url=https://tosstalk.com/pinephone/mobian/2020-09-08-Verizon.html][/url]
Mobian and T-Mobile make a great combo for Pinephone. This very close to "everything works". Does anyone know how to enter MMS APNs in Mobian/Phosh?
Someone Correct me if I am wrong Please,
I believe when the Developers have added it to the mainstream Mobian release,
It will simply be a few more blanks to fill-in on the APN settings page.
If it is possible at this time you will need to access it through the CLI/terminal
In settings under mobile network, below the toggles for data and roaming theres a button for APN names. Empty by default. You add your data one there, and i presume your mms one as well. For some reason i think you need to select a radio button on the APN name to activate it, essentially meaning you toggle between internet service or mms. I havent bothered with mms on debian yet, whilst most features do work at present it is way too slow to use. 15 secs for everything you click to open? No thanks. Its super promising, but im on the sidelines for this distro until it speeds up.
  2020-11-13 Image status. Gribouille 45 68,119 11-14-2021, 12:44 AM
Last Post: Gribouille
  Status update 2020-12-15 a-wai 33 65,063 01-13-2021, 07:14 AM
Last Post: scott_VYuCAbn3k1NFK
  My Daily QA - 2020-10-06 AmazingNutria 6 12,278 01-05-2021, 10:08 PM
Last Post: daniel
  Why the 12/15/2020 build is no where near a daily driver yet TheLastDon 24 39,452 12-31-2020, 09:51 AM
Last Post: HLing
  Status update 2020-11-15 a-wai 17 28,705 12-05-2020, 05:58 PM
Last Post: bcnaz
  Status update 2020-09-05 a-wai 26 49,606 10-12-2020, 01:50 PM
Last Post: dukla2000
  Status update 2020-10-05 a-wai 8 15,429 10-08-2020, 03:20 AM
  My Daily QA - 2020-09-22 AmazingNutria 4 8,984 09-25-2020, 08:33 AM
Last Post: bcnaz
  My Daily QA - 2020-09-11 AmazingNutria 2 5,891 09-20-2020, 09:17 PM
Last Post: daniel
  My Daily QA - 2020-09-10 AmazingNutria 1 5,027 09-11-2020, 08:30 AM
Last Post: daniel
