Bluetooth stylus
Can anyone suggest a capacitive stylus with right/lift click buttons? Seems like a basic product that should exist but internet searches have yielded nothing.
Edit: So they're marketed as active pens but seems linux support isn't their strong point. I guess keyboard/mouse will be a safer bet.
You may have some luck with this one but I can't find any references for Linux support: https://youtu.be/7jGSQdoA_kw
If I haven't been following SomeGadgetGuy, I wouldn't have known about the Bamboo Tip. Looks like it should be able to get the task done but I don't own one to tell for sure.
Device: Pinebook Pro 128GB No:246 / MainOS: Manjaro ARM
Godot and Flutter - creating something can be fun with the right tools!
My bad, I was focused too much on the stylus side and completely missed the button aspect.
An active capacitive (so just a finer finger) doesn't need Bluetooth to actually function. This is good as it will work with the PinePhone. Getting the secondary requirement - buttons, doesn't make the Wacom bamboo tip a good fit for your intended purpose
Thanks for the recommendation - I've read that a stylus may not play nice with screen protectors. Also, don't need pricey pressure sensitivity features. A right-click button would be handy for running a desktop shell distro.
That right click will be the question. It would certainly have to go through Bluetooth.
Now the thing is that most styluses that do have additional buttons, most of the time are pressure sensitive. The PinePhone doesn't have that pressure sensitive digitizer in the display making it incompatible with any of them.
This essentially eliminates the type of styluses you would find for example with the Surface Pro 3. The stylus with the SP3 can be connected via Bluetooth to utilize those additional buttons but it can operate without being synced. While it is an active stylus, it operates completely differently than the Bamboo Tip - the stylus with the SP3 is an alternative to the passive pressure sensitive styluses (both require additional layer/s in the display itself). Those can have some issues with screen protectors but the usual complaint is that they increase any paralax effect making precise drawing harder.
The active capacitive ones like the Bamboo Tip, end up working like your finger (except they need power to generate the current which would be picked up by the run of the mill display in phones within the small surface area of the tip). They aren't pressure sensitive and there are options that go for cheaper like this one: https://www.amazon.co.uk/AICase-Precisio...147&sr=8-5
Those active capacitive styluses are like the rubber ones you can grab for a few bucks except with a smaller surface area for the tip. Neither of those should have problems with screen protectors. However I don't know if someone is making a version of those "dumber" with a button (maybe in the same style as those Bluetooth selfie stick remotes).
PS: The only usage for a button on those non-pressure sensitive styluses I can think of, would be take a photo or act as "Play" button? iOS and Android are wholly unfit for such additional input :|
Any thought why different bluetooth devices aren't supported I was trying 2 different bt speaker doss soundbox touch and Boom 3, but only Boom 3 can't be recognized is this a software problem?
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 0 2,436 07-19-2024, 08:02 AM
Last Post: Peter Gamma
  Bluetooth keyboard with trackpad Zebulon Walton 11 17,822 06-29-2024, 04:09 AM
  can the pinephone be operated with a stylus? tuxcall 2 3,043 02-06-2023, 12:59 PM
Last Post: tuxcall
  Anyone have bluetooth headset working (for phone)? TRS-80 21 33,208 11-19-2021, 09:37 AM
Last Post: TRS-80
