[2/5/2016][DEPRECATED]Script to automate GUI installation on Ubuntu
#21
awesooooome. i am new on linux, let alone dev boards. thanks for the help
hi
i used that bash command and it provided me with options, but this error was returned. i used shutdown -r now to reboot but still the same error. have you seen this before?
(04-30-2016, 05:18 AM)dr5mn Wrote: awesooooome. i am new on linux, let alone dev boards. thanks for the help
hi
Try running "sudo fsck /dev/mmcblk0p2" before running the script. Let me know if this solved the problem.
Donate BTC: 3Eav9uqXi8Nx1axb7QjK6xV4km4K9YGv9a
#23
thanks for the feedback.
that drive is mounted, got
e2fsck: cannot continue, aborting.
then tried umount and sudo umount to unmount that drive, but just got
/: target is busy
should i try to reflash the ubuntu image to the sd card, or is there another solution?
#24
(04-30-2016, 09:28 AM)dr5mn Wrote: thanks for the feedback.
/: target is busy
If you have a linux system, you can insert the sd card into the system and try running:
sudo umount /dev/(the sd card partition containing the system) sudo fsck /dev/(the sd card partition containing the system)
Then insert it back to the pine64 and try running the script again.
If you don't have a linux system or if the above fails, the only option is to reflash the image.
#25
(04-30-2016, 10:24 AM)Terra854 Wrote: the only option is to reflash the image.
Really? What about issue 2 here: http://forum.pine64.org/showthread.php?tid=514
Is filesystem corruption considered something normal that can happen from time to time? Or might there be reasons for such stuff?
#26
I am aware about the counterfeit cards that are in circulation . I have planned to say later that if reflashing the image fails to solve the problem, then he should check to see if the card is counterfeit.
#27
this is a sandisk sd card, tried a few ones and got the same result each time. (i only buy real ones Smile )
i also followed all instructions to the letter. can't do fsck from the pine, kept telling me that /dev/mmcblk0p2 was mounted, and would not allow me to umount. if i put the card into another linux machine and do fsck it comes up with hundreds if not thousands of errors that need to be fixed.
fixed all errors by literally just holding in the y key, put card back into pine, ran the bash command and it executed the script by terra, but ended with another error: failed to fetch......components-arm64.yml.gz hash sum mismatch and also unable to parse package file......ports.....xenial_inrelease (1)
#28
(05-01-2016, 10:15 AM)dr5mn Wrote: this is a sandisk sd card, tried a few ones and got the same result each time. (i only buy real ones Smile )
And you still don't get it that you can buy counterfeit cards through every retail channel? Wow!
Filesystem corruption happens for a reason! And I still don't get it why the Pine64 folks do not adjust their burning instructions for OS images so that they read: "ALWAYS CHECK YOUR SD CARD FIRST! Before you didn't succeed with either H2testw or f3 don't even think about downloading any OS image". But fortunately that's their problem (and their user's -- mostly newbies to the SBC world)
#29
Thanks for the invaluable opinion and expert advice. The problem is clearly with all of the 5 sd cards I tried, from different brands and different retailers.
Is there anyone else who is willing to approach this like an adult and actually think of how we can provide a solution to the problem rather than an insult?
Sent from my iPad using Tapatalk
#30
(05-01-2016, 10:57 AM)dr5mn Wrote: The problem is clearly with all of the 5 sd cards I tried, from different brands and different retailers.
Great, and instead of running the recommended tests you're wasting your own and other peoples' time. Issue 2 lists not one but several reasons for data corruption: http://forum.pine64.org/showthread.php?tid=514
These issues all exist and it's easy to rule this out. Before this isn't done it's just a waste of time to continue. Happy further suffering.
  Issues with both Deb and Ubuntu germanshep 0 4,431 08-28-2018, 05:47 PM
Last Post: germanshep
  OpenWRT installation guide Sander 0 5,240 07-09-2018, 09:42 AM
Last Post: Sander
  Help debug my pine64A+ ubuntu/plex hangs XaRz 8 17,045 11-02-2017, 06:34 AM
Last Post: XaRz
  Ubuntu 16.04 cannot resolve dns - connection timed out; no servers could be reached marcosti 2 13,123 03-01-2017, 02:46 PM
Last Post: dkryder
Question Ultrawide Display for Ubuntu Mate DE dudeytsang 1 7,628 01-01-2017, 07:26 AM
Last Post: CaptainZalo
  [30/11/2016] pine64-config Terra854 10 24,356 11-30-2016, 08:15 AM
Last Post: Terra854
  SUNVOX - Software installation related topic janeku 17 36,116 11-26-2016, 01:06 PM
Last Post: janeku
  [09/10/2016] [ALPHA] Fedora Images for Pine64 Terra854 3 11,985 11-18-2016, 12:23 PM
Last Post: gregjo
  Pine64+Ubuntu+Tvheadend+DVBT Dongle Shai 3 10,685 10-03-2016, 04:23 AM
Last Post: Shai
  Dmesg output Ubuntu Mate S265 1 5,899 10-02-2016, 07:28 AM
Last Post: MarkHaysHarris777
