Phone won't charge in Mobian
Recently flashed an SD with Mobian and noticed that it isn't charging. Anyone else have similar issues? For what it's worth, I am on the most recent nightly build.
(08-30-2020, 04:59 PM)ragreenburg Wrote: Recently flashed an SD with Mobian and noticed that it isn't charging. Anyone else have similar issues? For what it's worth, I am on the most recent nightly build.
https://wiki.mobian-project.org/doku.php?id=tweaks
Quote:USB-C chargers / smart chargers not charging phone
This appears to be related to the kernel module for a chip in several USB-C-to-HDMI adapters. It can be fixed by blacklisting the module.
To fix it, create or edit the file
/etc/modprobe.d/blacklist.conf
and add the following line:
blacklist anx7688
Reboot, and smart chargers should now charge correctly.
PBP ISO / Debian Bullseye (unofficial installer)
blacklist anx7688
Thank you, that worked. I swear I looked through that portion of the documentation but must have been lazy about it.
Another possibilty without backlisting or removing the module would be to turn the phone off and then plug in the charger. Mobian will start and continue charging.
Rebooting won't do for this trick.
Hey thanks for the link, it is very interesting, for all the info there
I didn't have any problem charging. If we have the same phone and same OS, why some charge some don't? I am updating using apt every 2-3 days, never had the charging problem. Weird?
  Mobian MMS/SMS text problem bcnaz 16 37,770 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,513 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 65,536 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 71,793 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,244 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 336,757 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,925 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,011 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 4,722 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,444 04-29-2025, 02:10 PM
Last Post: mdk
