LTE modem datasheet links on the wiki are outdated
The pine64 wiki datasheet links for the LTE modem link to outdated files, also there are quite a few more data sheets available on the vendors product page (though I don't know if all are applicable to the modem in the Pinephone).
Here are the most recent versions of the files listed by the wiki:
https://www.quectel.com/UploadFile/Produ...n_V2.0.pdf
https://www.quectel.com/UploadImage/Down...ectel_EC25&EC21_AT_Commands_Manual_V1.3.pdf
A login seems to be required to access the various data sheets, but this can be circumvented by directly accessing the files using the base url "https://www.quectel.com/UploadImage/Downlad/" + "<file_name>.pdf".
For example, the link for "Quectel_EC25_Hardware_Design_V2.3" resolves to https://www.quectel.com/UploadImage/Down...n_V2.3.pdf
It would be nice if the wiki could be updated in that regard, thanks
It's the EG25-G, not the EC25....
Still an old version though. New version is 1.2.
I´ll try to correct that in the wiki
[x] done
Also corrected info about the modem being the EC25 version.
(08-21-2020, 03:11 AM)evilbunny Wrote: It's the EG25-G, not the EC25....
You're right, I guess I got too sidetracked by the wiki links of older revisions mostly pointing to EC25 files (as well as no mentioning of EG25-G in either Quectel's Linux driver source or Linux's mainline driver source).
Interestingly there doesn't seem to be command list datasheet available for the EG25-G, even though some of its datasheets reference a "Quectel_LTE_Standard_AT_Commands_Manual" (nowhere to be found online, maybe its not publicly available?).
Thanks for updating the wiki nonetheless.
edit: Looking at Quectel's Product Portfolio Overview I get the impression that EG25-G seems to be just a "global" version of EC25, so I guess most features/commands will work/behave in a similar fashion.
I've never been able to find a manual strictly for the EG25-G, but I have found manuals for the EC25, BG96, etc. and for the most part they seem to work on the EG25-G exactly as they would on their own.
For example, this manual for the BG96 seems to work with the EG25-G https://www.quectel.com/UploadImage/Down...e_V1.0.pdf (Although these commands are kind of useless atm on UT, been meaning to try again with the latest updates)
duckduckgo search: EC2x&EG25-G&EG9x&EM05_FILE_AT_Commands_Manual
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 24,090 09-11-2026, 09:18 AM
Last Post: idice
  Modem Issues with the Pinephone Temmie19 5 7,309 07-02-2025, 12:50 PM
  FOSS fw problem - PinePhonePro, EG25 modem dukla2000 5 7,091 02-05-2025, 02:30 AM
  Supported Carrier and Modem Bands NachoMomma 4 9,437 03-23-2024, 02:00 PM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 5,451 02-17-2024, 04:15 PM
Last Post: vortex
  modem not working michelinux 0 2,708 02-16-2023, 04:56 AM
Last Post: michelinux
  modem not detected al_x 3 9,421 02-15-2023, 11:17 AM
Last Post: fxc
  firmware udate Quectel EG25-G modem alwi 7 16,171 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 8,612 07-06-2022, 12:35 PM
  The modem does not recognize Korean SIM cards (what?) bdicewk 9 12,481 06-13-2022, 04:12 AM
Last Post: zetabeta
