Anbox for Debian
#21
(07-22-2020, 05:37 PM)nas Wrote: Looks like you have to add contrib to /etc/apt/sources.list for apt install to work but there appears to be a further problem with modprobe failing to find binder or ashmem in the kernel modules directory. I'm guessing there's a further step beyond enabling them in the kernel?
They're not modules anymore, so no need for modprobe now.
#22
(07-22-2020, 06:20 PM)a-wai Wrote: They're not modules anymore, so no need for modprobe now.
Seems the anbox container manager service tries to modprobe ashmem and then stops in error state.
This issue might give some clues, eg binderfs appears unset in current kernel config.
#23
Note: These instructions may be outdated, use them at your own discretion.
See below the updated instructions for installing Anbox, as of kernel version 5.7.
Derived from the original post. Thanks, @nas  Big Grin
  • Consider installing SSH to ease installation
sudo apt -y install openssh-server
  • The client may refuse to connect, if so...
sudo systemctl enable ssh.service && sudo systemctl start ssh.service
  • Determine the PinePhone's IP address
ip a s dev wlan0 | grep -oP 'inet .*' | cut -d ' ' -f 2
  • Connect from the client, optionally entering the PinePhone's IP address to the hosts file and copying the client's public cryptographic key
printf '%b' '\n192.168.0.10\tmobian\n' | sudo tee -a /etc/hosts ssh-copy-id mobian@mobian ssh mobian@mobian
Influenced by  LINMOBnet's video on Anbox.
rsync --progress ~/Downloads/anbox-image-working.tar.gz mobian@mobian:/home/mobian/Downloads
  • Append contrib to the default SourcesList
printf '%b' 'deb http://deb.debian.org/debian bullseye main contrib\n' | sudo tee /etc/apt/sources.list
  • Install the requisite packages
sudo apt -y install anbox adb
  • Unpack the Android archive
tar xf ~/Downloads/anbox-image-working.tar.gz sudo mv ~/Download/anbox-image/android.img /var/lib/anbox
  • Create a unit file for binderfs
printf '%b' "[Unit]\nDescription=binderfs\n\n[Mount]\nWhat=binder\nWhere=/dev/binderfs\nType=binder\n\n[Install]\n" \ "WantedBy=anbox-container-manager.service\n" | sudo tee /etc/systemd/system/dev-binderfs.mount
  • Edit the anbox-container-manager.service unit file
sudo sed -i 's/After=network.target/After=network.target dev-binderfs.mount/' /lib/systemd/system/anbox-container-manager.service sudo sed -i '6i Requires=dev-binderfs.mount' /lib/systemd/system/anbox-container-manager.service sudo sed -i '\_^ExecStartPre=/sbin/modprobe_s_^_#_' /lib/systemd/system/anbox-container-manager.service
  • Reload the service
sudo systemctl daemon-reload sudo systemctl restart anbox-container-manager.service && systemctl --user restart anbox-session-manager.service
The Anbox workaround originates from Mobian Issue #63. Thanks Djhg2000 Smile
  • Anbox must be open to allow installation of APKs via adb
anbox launch --package=org.anbox.appmgr --component=org.anbox.appmgr.AppViewActivity
  • Download and install an APK - APKMirror is a trustworthy source
adb install InsertAppName.apk
Android applications can be launched from the Phosh launcher (as .desktop files), or from the Anbox Application Manager.
Experimental: Implementing IP routing (for internet connectivity) and installation of MicroG is covered in the original post.
#24
I followed the guide but anbox session-manager still tries to load binder/ashmem kernel drivers.
Error:
[session_manager.cpp:136@operator()] Failed to start as either binder or ashmem kernel drivers are not loaded
But the anbox container manager is running.
#25
LINMOBnet uploaded a video about Anbox on Mobian.
Interestingly, Android's soft keyboards appear to be functional, but do not render.
#26
@Transistor4acpu Please try the updated instructions with the new workaround.
Apologies for the gratuitous whitespace - the WYSIWYG editor hates code fencing.
#27
anynbody tested anbox recently? is the keyboard still not working? I mean its working but it's invisible
I wonder which will become usable first, anbox or glodroid. whatever happens first will be my daily driver as I need whatsapp (for work). My current phone is in a desperate need for replacement, and it feels stupid buying another 150$ phone right now when pinephone is so close of being a usable device Smile
#28
I believe postmarketOS recently got Anbox working 'out of the box'.
I've not tried Anbox since updating the instructions above, so I'll add an edit to make it apparent that it may not be 'state of the art'.
#29
(09-15-2020, 03:44 AM)vanja Wrote: anynbody tested anbox recently? is the keyboard still not working? I mean its working but it's invisible
I wouldn't rely on anbox+whatsapp as a solution for work.
Better off waiting for a glodroid release which enables the modem - in the meanwhile, whatsapp works fine over wifi.
#30
I'm trying to get Anbox running in Mobian but am having trouble finding adb or android-tools-adb in the repositories. What repo is it in? I have bullseye main contrib enabled, but not found.
deb http://deb.debian.org/debian bullseye main contrib non-free
For keyboard, it seems that using virtboard instead of squeekboard should work??
  atinout binaries for mobian/debian? NeutralGrey 4 5,852 10-31-2024, 04:16 AM
Last Post: astylethargic
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 18,569 08-31-2023, 12:38 PM
Last Post: vusra
  Debian bookworm security repo user641 2 5,240 02-17-2023, 01:12 AM
Last Post: user641
  Gnome-podcasts on Debian repos user641 4 7,454 02-06-2022, 04:58 AM
Last Post: jsch
  gnome podcasts on debian repo, dino-mobile user641 3 7,025 09-11-2021, 12:04 AM
Last Post: user641
  Best/easiest way to install minimal Debian on PinePhone? mcgee 6 11,626 07-18-2021, 09:35 AM
Last Post: swiley
  How does calls work in debian? temp0rary 4 8,719 05-31-2021, 10:44 AM
Last Post: temp0rary
  Whatsapp in Anbox scott_VYuCAbn3k1NFK 7 15,941 03-22-2021, 08:46 AM
Last Post: Skyrrd
  Debian/Mobian packaging help needed arno_nuehm 1 4,222 03-20-2021, 04:59 PM
Last Post: TRS-80
  Anbox apps listed in the launch screen mark1250 1 5,054 03-17-2021, 02:23 PM
Last Post: tvall
