earpiece sound setting
I use pinephone Brave Heart edition with mobian as daily phone. It nearly works fine for my use. Thanks a lot for mobian !
I still have an issue to set correctly the volume of the ear piece. When I set it whith alsamixer or phosh settings, the value is sometime changed (during reboot for instance).
In alsamixer, master is at 100%, and earpiece at 100%. It is too much for my earpiece that is sounding very bad, making phone call difficult to hear because volume is too high with a lot of cracks. The range where the sound is ok is very small compared to the setting range in phosh settings. If I change the values in phosh settings and make a test of earpiece and go back to alsamixer, those values are back again to 100%.
I don't know which part of the software is storing the sound settings, I guess, it is not alsamixer. So if you can explain me how it is dealt with, I would be extremely gratefull.
Is there a way to avoid sound setting changes if not manually applied by the user ?
Thanking you in advance for your help !
* PinePhone BraveHeart Edition
@Gobelin
I have the same phone with Mobian August 10 nightly release running on SD card.
I wish I could turn my volume up a bit.
I think I saw a post by a-wai saying the volume controls will  be soon included a new release.
You probably need to go digging through the PulseAudio and alsa docs to see if there's anything you can do as a workaround until this is supported. PulseAudio profiles use alsa UCM profiles if they exist. For the PinePhone the packaged ones are in /usr/share/alsa/ucm2/PinePhone/ so if you edit them your changes will most likely be overwritten by any package update. There's a cli tool called alsaucm that can manipulate these, but I don't know how/whether it lets you change the volumes set in the EnableSequence sections, and how/whether these changes would be persistent.
thank you wibble !
Thanks a lot,
in /usr/share/alsa/ucm2/PinePhone/VoiceCall.conf I edited the line :
cset "name='Earpiece Playback Volume' 100%"
to
cset "name='Earpiece Playback Volume' 60%"
and called someone who doesn't sound like a robot !
That will change my life ! (PinePhone is my only phone, I live braveheart style).
  Sound : notifications freelectro 6 8,577 06-07-2023, 01:03 AM
Last Post: freelectro
Exclamation No sound anonymous 22 26,921 11-08-2022, 09:07 AM
Last Post: dante404
  Date & Time-setting app is a very poor design treebeard 6 8,630 07-27-2022, 06:35 AM
  My sound went away with calls... Not sure what happened. How can i fix it? usourypg3i 4 6,711 02-18-2022, 08:54 AM
Last Post: battlegarden
  Lost all sound Dinosaur1946 0 2,967 01-27-2022, 07:34 PM
Last Post: Dinosaur1946
  Sound design for Mobian S.E.B 4 7,083 12-27-2021, 05:40 AM
Last Post: Anna
  Mobile network mode setting not saved Zebulon Walton 3 6,554 12-05-2021, 12:12 AM
Last Post: bcnaz
  Setting up Mullvad to run on Mobian Azathoth 2 4,959 11-09-2021, 01:03 AM
Last Post: j4n3z
  Make scale setting persistent 3x5co 2 4,648 10-26-2021, 05:57 PM
Last Post: 3x5co
  Re-do First Time Setup / Location Services Setting (How?) calinb 3 7,659 01-01-2021, 08:03 PM
Last Post: calinb
