How to get Netflix to work in Chromium or Firefox on PBP
(08-09-2020, 11:48 AM)clover Wrote: Would the chromium armhf trick work on a distro like Ubuntu/Elementary OS?
I don't know.  Does Ubuntu/Elementary OS show a docker package in the software repository?My understanding is that the two issues are Widevine not being available for the arm64 / rock chipset used in the PBP and that coupled with being a 64 bit chip.  My understanding is the docker package allows a "container" to  be created for the Chromium armhf to run in.  I don't know that my understanding is very deep as I am definitely a noob with Linux/Arm64/PBP/Manjaro.
Try it and see!  Unlikely to see any thing other than it doesn't work.
Try it and see!
Ok, it works Smile
https://twitter.com/AlexRob12252696/stat...0679288849
There is a Netflix plugin for kodi.
https://github.com/CastagnaIT/plugin.video.netflix
It is SW decoding only, but it does work. (I use it on a raspberry pi). Kodi is readily available in basically all distros
Just tried the Chromium Docker solution.
It works but the video quality is poor and the audio won't go through Bluetooth.
  Ctrl + Shift + Tab not working in Firefox Bolitoglossa 2 7,279 08-21-2020, 04:05 AM
Last Post: Bolitoglossa
  Will the Rock64 work as a mobile data storage device? Kennetht 1 5,263 03-29-2018, 10:07 AM
Last Post: xalius
  Running Netflix marcostt 4 11,667 10-09-2017, 09:50 AM
Last Post: marcostt
  7" Screen - Does it work with Debian abasel 1 6,298 07-26-2017, 05:44 AM
Last Post: pfeerick
Video May dietpi save Pine64 ; watch youtube via chromium hatahata 12 29,342 03-09-2017, 07:41 PM
Last Post: pfeerick
  Would the SOPINE modules work if they were put into a standard SODIMM RAM slot? Wiooooo 4 11,020 02-05-2017, 02:57 PM
Last Post: MarkHaysHarris777
  Just Received my Order; It Doesn't work?! kikootwo 4 11,746 08-11-2016, 09:05 PM
Last Post: Mpoint
  Helpful Hint: HDMI-to-DVI cables do not work on PINE64 aegrotatio 4 13,029 06-07-2016, 11:02 PM
Last Post: aegrotatio
  Unable to get edimax wifi dongle to work with archlinux on Pine64 g3tinmybelly 9 20,380 04-27-2016, 06:48 PM
Last Post: g3tinmybelly
  Does any Os work yet? ianrob99 4 10,264 04-25-2016, 04:15 AM
Last Post: Keex
