New UBports edition - black screen (backlight) only
(08-04-2020, 11:13 AM)wibble Wrote: Have you tried booting a known stable image like Jumpdrive from the SD to rule out the software as the cause? https://wiki.pine64.org/index.php?title=..._Jumpdrive
What you're describing reminds me of what some people have reported with UBports after an unclean shutdown - it gets stuck when trying to mount one of the filesystems.  They've fixed it by booting another OS on the SD to run fsck on the eMMC filesystems, or to reinstall UBports or another OS on the eMMC. If you want to find out what's actually going on behind the blank screen you can use the headphone socket as a serial console.
I flashed Jumpdrive to a microSD card using "dd if=pine64-pinephone.img of=/dev/sdc bs=1M", inserted the SD card and booted the Pinephone. I get a green LED, then the screen backlight lights up but no image on the screen.
Is it safe to say I have a bad screen and need to file a RMA request?
You've ruled out the most obvious software based problem, so it's probably a good time to contact them. The serial terminal would tell you more if you have the required hardware. Beyond that you'd have to open it up - some people have found incorrectly seated connectors, and solved problems by reseating them - so in your position I'd want to get the OK from Pine64 first. They may have some other things for you to check before RMA.
  Screen dying already? marcih 156 308,548 06-12-2025, 06:18 AM
Last Post: mikeb
  Screen Replacement Instructions erikkugel 5 12,330 02-24-2025, 06:55 AM
Last Post: anonymous
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 2,084 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 6,805 10-12-2023, 01:03 PM
Last Post: robthebold
  No calls on Pine Phone Beta convergence edition polypode 1 3,803 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 46,796 01-29-2023, 12:20 PM
Last Post: skandigraun
  BETA edition rcu errors 8bit 29 44,328 11-02-2022, 01:40 PM
Last Post: some_pinephone_user
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 8,767 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 4,779 07-03-2022, 06:27 AM
Last Post: Avisando
Question Upgrading a 2020 Community Edition Pinephone? danimations 5 9,581 03-10-2022, 08:18 AM
Last Post: danimations
