PineA64 Getting Started Guide
We have created a Getting Started Guide on out Wiki page. Please refer to the link below,
http://wiki.pine64.org/index.php/Main_Pa...t_Guide.5D
All the startup guides seems to be software related, have only seen one video on install your pine in the acrylic case. Nothing on how to install modules like wifi/Bluetooth or zwave.
nothing on where to use the power button
(07-02-2016, 07:52 PM)grantos Wrote: All the startup guides seems to be software related, have only seen one video on install your pine in the acrylic case. Nothing on how to install modules like wifi/Bluetooth or zwave.
Even without videos for installing modules, the logic to figuring it out by DIY is quite simple. You will find labels and numbers around pins. I wouldn't expect full tutorials like a full completed product would do, as this is a maker board. It's all DIY and trial and error, try things out man!
For the power button, it can be used as either a reset or power button. You will find a marked area for installing the button as a reset or power button if you look closely on the board.
Sorry but are newbies not allowed. I have never installed modules before. But lucky the wifi/ Bluetooth module is only one way. But I'm getting a poor signal
(07-05-2016, 07:46 AM)grantos Wrote: Sorry but are newbies not allowed. I have never installed modules before. But lucky the wifi/ Bluetooth module is only one way. But I'm getting a poor signal
Have you attached the grey antenna cable yet? It improves signal considerably.
(See this image.)
(See this image.)
Thanks ghost still trying to check image as it won't load in app.
Cable is attached to module but not sure where to glue/stick other end that had 3M tape?
(07-06-2016, 07:13 AM)grantos Wrote: Cable is attached to module but not sure where to glue/stick other end that had 3M tape?
As far from the board as possible (which isn't that far, because the cabling isn't too long).
Mine is stuck to the acrylic case and works ok.
Ok seen image finally , have spun cable around so it sticks out side. Hope to see drastic wifi improvement
Stuck mine down outside case made NO diff to signal strength, basically getting no bars on wifi readout
@grantos: which operating system are you using? Are you using LCD Touchscreen or HDMI TV/Monitor?
You could try another operating system (or another earlier/later version of the same OS) to see if the issue is software-related.
(07-06-2016, 11:53 PM)Ghost Wrote: @grantos: which operating system are you using? Are you using LCD Touchscreen or HDMI TV/Monitor?
Cheers @Ghost.
that was one of my next solutions, also pine accidentally sent two wifi modules so will try that also.
Do you have pic of how you attached yours
Currently using remixes on 2gb board
Using HDMI on a TV fixed image by turning over scan off
Wink Where should I post a PineBuds Pro repair and battery replacement guide? waitingpio 3 997 08-08-2026, 06:56 PM
  Guide: Setup Latest Waydroid for Hardware Acceleration and/or Development nroth 2 15,526 11-11-2022, 04:47 PM
Last Post: nroth
  Getting started in nRF52 in pinetime64 Quim 0 3,664 06-14-2020, 02:02 PM
Last Post: Quim
  Any success working with OpenCV on the PineA64? Tonny91 0 3,781 10-16-2018, 09:16 PM
Last Post: Tonny91
  How to get started? riahim 35 96,516 10-19-2017, 02:04 PM
Last Post: hikmetsezen
  PineA64 512 reboot - board shut down indrajith 7 18,854 07-28-2016, 02:07 PM
Last Post: Ghost
  Startup Guide (READ THIS FIRST) ScorpionTNT 3 9,923 07-18-2016, 10:33 AM
Last Post: Luke
  Getting started using OSX cranchh 17 45,475 06-23-2016, 11:40 AM
Last Post: killorfb
  Youtube video on PineA64 Development Board khgoh 0 6,749 03-30-2016, 11:25 PM
Last Post: khgoh
