Announcing the Mobian project
(07-21-2020, 09:36 PM)bcnaz Wrote: Update :
  Flashed the July 21 nightly to sd card and still no SMS text on my Brave Heart phone.
                                Cry
I have about 14 July nightly with daily update && upgrade. Incoming SMS works fine for me (at least for my 2FA from bank an hour ago  Smile )
                                Cry
( The text icon disappeared from the contact book,  still has the handset icon for the phone.)
I am downloading the July 01 release ATM,  going to try that later today.
@a-wai Where do we post issues for Mobian? So far I ran into some concerning cellular and made a post here on Pine64 forums. https://forum.pine64.org/showthread.php?tid=10797
Im running it on a UBports edition Pinephone and my T-mobile sim card is not getting cellular.
The repositories are under https://gitlab.com/mobian1 where there's a general bug tracker plus individual ones if you know the component the bug is in.
@FOSSagent0 Either create an issue in gitlab or
in the bugtrackers of the upstream software (if you run into a specific issue and have identified the program which is misbehaving).
Donations ?
 I do not see any method to use PayPal   only Libre pay  ?
     ( I only use PayPal )
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
For those more skilled with phosh than I am - is there a way to disable/remove the PIN security screen?
I find it irksome that to wake up my phone I need to
  1. Push the power button
  2. Slide up the unlock screen
  3. Enter a PIN
and would love to only do 1 or 2 of the steps!
I have tried playing with the Settings, Privacy, Screen Lock options with no progress. I am hoping there is something I can do to disable a service or tweak an option in phoc.ini but despite spending quite a bit of time with Prof DuckDuckGo am still stuck with a rather clunky 3 step wakeup!
Phosh accepts the -U flag which can be used to start the session unlocked. I'm not sure however if this also prevents it from going to the lockscreen.
PS: I only tried this while running a nested phosh/phoc inside my WM/DE.
Hi All!
I still have this SIM problem, so with my Vodafone HU card everything works fine, but my Telenor one can access only 3G and there is no mobile data.
nmcli dev status says the cdc-wdm0 connection is disconnected. I have the correct APN name in a settings, so is there a way I can access mobile data, etc?
Thanks!
(07-27-2020, 02:05 AM)cefre00 Wrote: Hi All!
Thanks!
Hi!
Here are the settings screenshots for the Hungarian TelenorHELLO subscription.
.png   apn.png (Size: 89.43 KB / Downloads: 573)
.png   mobile_apn.png (Size: 51.27 KB / Downloads: 545)
.png   mobile_settings.png (Size: 108.35 KB / Downloads: 628)
.png   network-settings.png (Size: 54.31 KB / Downloads: 586)
.png   modem-details.png (Size: 110.75 KB / Downloads: 549)
  Mobian MMS/SMS text problem bcnaz 16 34,099 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 851 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 59,502 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 68,610 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 2,795 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 321,987 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,508 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,401 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 4,042 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 3,838 04-29-2025, 02:10 PM
Last Post: mdk
