Boot From USB
Just wondering if it's even possible I tried it once and it didn't work. Thank you  Big Grin
(04-27-2016, 06:37 AM)Jon_30 Wrote: Just wondering if it's even possible I tried it once and it didn't work. Thank you  Big Grin
Not possible
Is it because we can't access the bios to choose where it looks first in the boot sequence?
There is no BIOS in the traditional sense.
The device uses U-Boot, and a custom one at that. Thats about the sum of what I know, more good info is avail here https://github.com/longsleep/u-boot-pine64 thanks to longsleep.
Bios was a function set for larger implementations. Keep in mind that SOC based platforms are usually designed for very specific and very code limited application when it comes to OS launching. That means that the BIOS wasnt needed. Good generic info on U-Boot is avail here http://www.denx.de/wiki/U-Boot/DesignPrinciples
(04-27-2016, 12:54 PM)rahlquist Wrote: There is no BIOS in the traditional sense.
Oh I was a bit confused on how pine64 booted. Thanks! Tongue
  Pine Board using linux stuck during boot sequence ktaragorn 4 14,753 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Secure boot & OTP efuse program devangpanchal90 0 4,208 05-25-2018, 01:59 AM
Last Post: devangpanchal90
  boot process for pine a64 awaysu 1 6,690 01-24-2018, 05:09 AM
Last Post: xalius
  Can't boot headless after running update_uboot.sh Borglesnorgle Williams 2 7,317 08-17-2017, 04:08 AM
Last Post: Borglesnorgle Williams
Exclamation Pine A64 Plus Fails to Boot grobbs 35 71,433 06-28-2017, 08:53 AM
Last Post: sarav_sara
  Boot issues: What todo when you muck up your FSTAB file Dagremote 1 6,293 04-16-2017, 10:28 PM
Last Post: pfeerick
Question Pine64 cannot boot jamiechang917 6 15,441 04-16-2017, 10:21 PM
Last Post: pfeerick
  U-Boot for A64 git longsleep 38 104,666 03-21-2017, 01:59 PM
Last Post: longsleep
  OpenWRT supports ARMv8 - arm64, u-boot problem? rgdonato 4 11,199 03-20-2017, 03:59 PM
Last Post: rgdonato
  USB OTG Boot devilsclaw 25 64,745 03-01-2017, 03:22 PM
Last Post: CaptainZalo
