Mobian snd_seq not installed
I've been trying to get Mame and a midi sequencer called "drumstick" to work on Mobian, and I keep getting an error where /dev/snd/seq file or directory not found.
Both crash while starting
Apparently the kernel was compiled without CONFIG_SND_SEQUENCER set, therefore snd_seq wasn't compiled into the kernel.
Can the flag be set in an upcoming update? I don't even know what the sound hardware on the Pinephone is.
Also there doesn't appear to be a modprobe for Mobian.
ScummVM works, (I played Full Throttle with full audio, no problems) and I suspect the error has something specific to do with MIDI sequencing.
edit: modprobe's there, I forgot to sudo when I ran it and just assumed it too was missing.
Thanks for reporting this issue! Sequencer support is now included in the latest kernel, once you upgrade and reboot Smile
(07-21-2020, 04:50 PM)a-wai Wrote: Thanks for reporting this issue! Sequencer support is now included in the latest kernel, once you upgrade and reboot Smile
BLESS YOU!
  Printing from Mobian johnd 3 5,134 10-27-2026, 06:01 AM
Last Post: PrinterSolvedTeam
  Mobian MMS/SMS text problem bcnaz 16 41,098 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 2,117 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 71,848 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 75,350 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,624 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 358,683 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,304 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,571 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,307 05-06-2025, 02:19 AM
