GloDroid (Android-13)
GloDroid (AOSP for the world's most accessible development platforms)
PinePhone:
https://github.com/GloDroidCommunity/pine64-pinephone
PinePhonePro:
https://github.com/GloDroidCommunity/pin...nephonepro
Releases (Prebuilt images are available under the assets drop-down list):
https://github.com/GloDroidCommunity/pin...e/releases
Newpipe picture-in-picture works without too many crashes - here's a quick video showing how glodroid performs.
.jpg   glodroid-pip-pinephone.jpg (Size: 31.1 KB / Downloads: 2,069)
Any idea when we may have calling / gps / camera in glodroid?
Unknown but in the meanwhile playing with the current release.
I had no luck with mupen64plus in retropie on debian but installed it on glodroid and n64 emulation works pretty well - here's a blurrycam video of the results Wink
.jpg   pinephone-mupen64plus.jpg (Size: 28.81 KB / Downloads: 1,340)
pushing the pinephone a bit further - dreamcast emulation is probably the limit but the reicast virtual joypad doesn't want to work. Controls work on the flycast core in retroarch but sound stutters more - here's a quick video demo.
.jpg   reicast-pinephone.jpg (Size: 24.48 KB / Downloads: 1,407)
Probably cameras will be next Milestone.
Has anyone found a workaround for bug 39? https://github.com/GloDroid/glodroid_manifest/issues/39
I also tried downgrading to 0.2.0, but that has its own bug: the phone boots but the screen remains blank.
(07-09-2020, 03:56 PM)nas Wrote: Newpipe picture-in-picture works without too many crashes - here's a quick video showing how glodroid performs.
Do you have instructions or script to install Glodroid on pinephone?
(07-30-2020, 05:13 PM)lcayer1 Wrote: Do you have instructions or script to install Glodroid on pinephone?
Go to release page and click on assets dropdown arrow. For latest version, download gd-pinephone-v0.3.0.tar.gz and extract archive to a folder.
Then follow Deploying GloDroid instructions on main page but summarised:
1) flash sd card with  deploy-sd-for.emmc.img
2) insert sd card in phone and connect to pc with red usb cable
3) phone display will remain black but wait 10secs
4) open terminal on pc and goto directory where archive extracted
5) run install script, eg  bash ./flash-emmc.sh
6) when script pauses, hold power button for 10secs, disconnect cable
6) remove sd card, reconnect usb cable and press enter
7) phone will display fastboot menu and script will continue
8) if failure message, run install script again
9) if success message, reboot phone to start android
0) if adb not already installed on pc then  sudo apt install adb
X) don't want install to emmc? substitute with deploy-sd.img
and flash-sd.sh
Z) some reports of usb issues which prevent deploy method of install - in which case, read this thread or download v0.20 and flash as a regular image
6) remove sd card and reconnect usb cable
and flash-sd.sh
Thanks a bunch, Nas!
  GloDroid (Android-14) GaryM 1 6,889 04-17-2024, 08:39 AM
Last Post: GaryM
Tongue Android Auto on Pinephone via Waydroid: a pipe dream? slondr 1 5,884 11-06-2022, 01:46 PM
Last Post: wibble
  difference between android and linux? vanja 3 6,368 09-16-2022, 07:43 PM
Last Post: TRS-80
  Android and Google Play Store on a PinePhone? Solra Bizna 22 62,969 11-01-2021, 07:11 AM
Last Post: digitalmouse
  Easiest way to use Android applications on Pinephone esud 4 16,589 06-21-2021, 04:52 AM
Last Post: vanja
  Remote connection from Linux Mobile to unrooted Android? (surely very useful?!) 4w7gvrvsjcyvd 0 3,577 01-30-2021, 06:48 PM
Last Post: 4w7gvrvsjcyvd
  pine phone came with android? andrewiassur 1 5,553 04-11-2020, 02:06 PM
Last Post: fire219
