Camera support progress
Splendid work! hats off
It even takes cat pictures. Very exciting.
.jpg   2020-07-07_08_48_38.jpg (Size: 147.89 KB / Downloads: 1,130)
IT WORKS!!! Great work! Amazing! so far front camera only, and yeah, the image quality leaves something to be desired, but IT WORKS. AND it saves the .jpg with a date stamp filename in home/usr/pictures. LOVE IT
Mine does not work unfortunately. But it seems that nothing works on my PP. Big Grin
(07-06-2020, 04:59 PM)bendavey Wrote: It even takes cat pictures. Very exciting.
Your cat does not seem particularly pleased though :P
Can confirm it works! kudos!
Tested today's nightly - works like a charm! good job Smile
Working here too Smile Smile
Camera is quite laggy , but heyyy IT WORKS Cool
Thanx again for your big effort
/Bingo
#19
works but super slow cant move fast
#20
This is not working for me, on my Braveheart PinePhone. Here's the dmesg output:
mobian ~$ dmesg | grep -E "(csi|ov5640)"
[    1.425837] dovdd-csi: Bringing 3300000uV into 1800000-1800000uV
[    1.428194] avdd-csi: Bringing 2900000uV into 2800000-2800000uV
[    1.430261] dvdd-csi: Bringing 700000uV into 1800000-1800000uV
[    4.172849] i2c-gpio i2c-csi: using lines 141 (SDA) and 140 (SCL)
[    8.972532] sun6i-csi 1cb0000.csi: creating ov5640 3-004c:0 -> sun6i-csi:0 link
[    8.979971] sun6i-csi 1cb0000.csi: creating gc2145 3-003c:0 -> sun6i-csi:0 link
[    9.918406] ov5640 3-004c: ov5640_init_slave_id: failed with -6
[  11.526450] ov5640 3-004c: ov5640_init_slave_id: failed with -6
[  39.310878] ov5640 3-004c: ov5640_init_slave_id: failed with -6
[  40.475398] ov5640 3-004c: ov5640_init_slave_id: failed with -6
Camera shows a test pattern when I run it, indicating that no cameras are detected at all.
I flashed Mobian to my SD card from the mobian-pinephone-20200707 image, then upgraded using "sudo apt upgrade" (only one package, pinephone-tweaks, was updated), then restarted.
  camera not usable with trixie? JChdeL 0 893 12-05-2025, 01:45 AM
Last Post: JChdeL
  Switching cameras on PPpro Camera app biketool 0 964 11-11-2025, 10:44 AM
  New camera app gnome-snapshot working on trixie? vusra 4 4,440 04-11-2025, 02:53 AM
Last Post: vusra
  The program doesn`t detect the camera blag0rag 6 6,270 09-17-2024, 03:45 PM
  Could not initialize OpenGL support jojuma 6 10,537 09-14-2024, 12:06 PM
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 3,689 07-17-2023, 01:49 AM
Last Post: junelung
  Trying the camera switch on my PinePhone gilwood 5 7,772 04-02-2022, 12:54 PM
Last Post: jhasler
  Bluetooth audio support? Zebulon Walton 5 8,282 02-28-2022, 08:59 AM
  Mainline MMS Support?? tyha 2 4,597 01-06-2022, 03:25 PM
Last Post: bcnaz
  mobian, pinephone camera, and megapixels dawg161 32 52,889 05-01-2021, 02:34 PM
Last Post: NormandC
