Announcing the Mobian project
#91
(07-01-2020, 04:21 PM)bcnaz Wrote: Text does "work"
But I am getting 3 copies of every incoming message ?    ( Just Me ?  )
 Just now flashed July 03 nightly build to my SD card,   plus I did an 'update'....
  I am now getting one copy of each incoming text
   > Flashlight icon is on the app screen and it works !   Nice
     the manual GUI  'update'  is working for me again.
but using the text app does occasionally cause the phone to reboot, but the reboot is now faster
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
#92
Update :
On a fresh boot, I cannot seem to open/originate my text App.
  I use my 'back-up phone' and send a fresh text to my Mobian phone that allows me to open the text App.  (?)
    Once it is opened, it re-opens as it should.
#93
I am curious about the accuracy of the reported battery voltage.
when it says : 100% charged 4.19 V ?
89% charged 3.95 V ?
This is a 5 V battery ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
#94
Lithium ion batteries typically have a maximum voltage of around 4.2V, and minimum around 3.0V. They're usually marked as a nominal 3.7V. Reported voltages look correct.
#95
Thank you, I did not know that.... ( Now I DO )
B.C.
#96
Is there a difference between getting a nightly build then updating that fully compared to the mobian-pinephone image from june 15, I assume there would be. how much does the mobian-pinephone image lag behind vs a nightly build?
#97
(07-07-2020, 09:30 PM)gizmuth Wrote: Is there a difference between getting a nightly build then updating that fully compared to the mobian-pinephone image from june 15, I assume there would be. how much does the mobian-pinephone image lag behind vs a nightly build?
Hi.
In my opinion, just use the command line and do an sudo apt update && apt distupgrade. Or use the software-center and look for updates. It worked for me. I got yesterday and today an operation system update. Try it out. Regards kowalskie.
Best regards
Andre (Lower Saxony, Germany)
#98
Hi All!
I couldn't find a good thread to post this question, so I decided to ask it here and then your are free to redirect me: my Hungarian Telenor SIM card does not seem to work with the Pinephone BH with Mobian. My Vodafone one works like a charm, Telenor suck ass, but I did not know that this hard.
According to the links below the modem should cover the bands the service is using, but still: nothing works.
https://www.frequencycheck.com/carriers/telenor-hungary
https://www.omgubuntu.co.uk/2019/11/pine...lease-date
Is there a way or where should I start digging to make this work?
Thank you in advance for your help!
#99
(07-09-2020, 01:43 AM)cefre00 Wrote: Hi All!
I use a Telenor Hello SIM in Hungary, it works for me. The APN for the mobile data is "online".
I hope, this helps.
Hi there,
I am impressed how well Mobian works on the Pinephone. However, notifications for Telegram are not working right now, is that correct?
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 50,347 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 35 63,626 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 30,906 09-15-2025, 02:42 AM
Last Post: georgegohl888
  XLibre for Mobian Hiraghm 0 2,438 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 296,135 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,206 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 2,919 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 3,442 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 3,324 04-29-2025, 02:10 PM
Last Post: mdk
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 3,448 01-15-2025, 08:08 PM
