[2/5/2016][DEPRECATED]Script to automate GUI installation on Ubuntu
(04-24-2016, 07:58 AM)Terra854 Wrote: Hello everyone.
The script has now been updated. This update includes major changes to the script that will now install a more complete environment rather than the bare minimum of components.
Github link is in the first post.
I also pin the first post, you can edit and update. Thanks on your contribution.
You're welcome.
Anyway, the script has now been updated.
Latest changes:
- The 'fix-whatever' shell script by longsleep will now execute automatically after the environment is installed
- Root is now required in order to execute the script
Donate BTC: 3Eav9uqXi8Nx1axb7QjK6xV4km4K9YGv9a
why not use something like tasksel?
sudo apt-get install tasksel dialog
sudo tasksel
then select your DE Wink
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
(04-25-2016, 11:54 PM)lenny.raposo-pine64.pro Wrote: why not use something like tasksel?
sudo tasksel
Because this script will also expand the rootfs partition and fixes common problems in the Ubuntu system. Also, additional packages and drivers will be installed that will make Linux work better on the Pine64.
Wouldn't it make sense to update uboot and kernel (longsleep's scripts) and rootfs resize, reboot then begin installing a major DE?
Just wondering Wink
Cheers Big Grin
(04-26-2016, 06:18 AM)lenny.raposo-pine64.pro Wrote: Wouldn't it make sense to update uboot and kernel (longsleep's scripts) and rootfs resize, reboot then begin installing a major DE?
Just wondering Wink
It is assumed that the uboot and kernel is already at it's latest version before this script is executed. So, I did not call the update uboot and kernel scrpts in my utility. However, there are plans for the utility to execute the update scripts in the near future if there is a need for it.
anyone else having this stall out ? been at 32% for quite some time.
https://drive.google.com/file/d/1PTlz2uJ...sp=sharing
**never mind, screen must have kept the progress where it stopped reporting.. spacebar brought up the refreshed progress.
Great job Terra854 !!! I used longsleep's image and then used your script to install xfce DE. Everything looks good. Able to browse with midori browser. Video on youtube has a lot of stutter..audio is fine though.
My Logitech wireless media keyboard worked right out of the box.
My next steps would be to try and get plex/emby working on this (with no transcoding). I intend to use this as a headless media server until I can afford a bigger beast  Wink  !!!
Thanks.
Note: Instructions on how to get the file from Google drive to the pine itself would help some beginners, as there is no UI/browser before they can run your script.
#19
hi
i just get the following message after running sudo install...
sudo: install-ubuntu-gui.sh: command not found
should i copy install-ubuntu-gui.sh to my sd card first, or am i missing other steps?
can you please assist?
#20
(04-30-2016, 05:04 AM)dr5mn Wrote: sudo: install-ubuntu-gui.sh: command not found
sudo su -
bash <(curl -s https://raw.githubusercontent.com/Terra854/pine64-ubuntu-gui/master/install-ubuntu-gui.sh)
  Issues with both Deb and Ubuntu germanshep 0 4,225 08-28-2018, 05:47 PM
Last Post: germanshep
  OpenWRT installation guide Sander 0 5,020 07-09-2018, 09:42 AM
Last Post: Sander
  Help debug my pine64A+ ubuntu/plex hangs XaRz 8 16,184 11-02-2017, 06:34 AM
Last Post: XaRz
  Ubuntu 16.04 cannot resolve dns - connection timed out; no servers could be reached marcosti 2 12,760 03-01-2017, 02:46 PM
Last Post: dkryder
Question Ultrawide Display for Ubuntu Mate DE dudeytsang 1 7,348 01-01-2017, 07:26 AM
Last Post: CaptainZalo
  [30/11/2016] pine64-config Terra854 10 23,229 11-30-2016, 08:15 AM
Last Post: Terra854
  SUNVOX - Software installation related topic janeku 17 34,372 11-26-2016, 01:06 PM
Last Post: janeku
  [09/10/2016] [ALPHA] Fedora Images for Pine64 Terra854 3 11,443 11-18-2016, 12:23 PM
Last Post: gregjo
  Pine64+Ubuntu+Tvheadend+DVBT Dongle Shai 3 10,194 10-03-2016, 04:23 AM
Last Post: Shai
  Dmesg output Ubuntu Mate S265 1 5,657 10-02-2016, 07:28 AM
Last Post: MarkHaysHarris777
