Red Pinephone USB-C cable.. just for charging, right?
Hi everyone,
Just wanted to check in and see what others have found with the cable received with the PinePhone. Mine is red, I thought it was a standard USB-C cable but it turns out it only works for charging. I tried plugging in this cable to an android phone and linux PC, the lsusb command comes up with nothing/can't find device. Switched to another cable to find that it does work as a standard usb cable, data transfer/charge capable.
Hopefully it is as designed, just for charging.
(06-30-2020, 01:55 PM)djvinniev77 Wrote: Hi everyone,
That's odd, from my experience it's perfectly capable of Data Transfer. Works when I use it for my 1 TB external SSD and it works when running JumpDrive on the microSD card to install an OS on the eMMC.
Works for data for me too. It even works so well that I am currently using it as a link cable for my Oculus Quest.
The PinePhone USB-C cable color RED indicate this is a power cable. This cable has USB 2.0 D+ and D- line due to some power supply using this two data line to determine supply current. The power lines (VBus and Ground) inside this cable have been thicken, capable of handles up to 4A and also low resistor value to minimize power loss (voltage drop). You can use this cable as an USB 2.0 cable.
  Pinephone (Pro) Keyboard Case for sale manubert 7 15,703 02-08-2026, 07:41 PM
Last Post: Ondy
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 1,228 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 6,651 06-03-2025, 04:19 PM
Last Post: j_s
  keyboard case charging but not typing new2pinephone 19 21,431 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 4,049 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 16,946 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 4,227 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 3,953 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 2,186 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 3,546 06-29-2024, 09:36 PM
