Mobian stuck in bootloop
Hey all,
I flashed the 16/06 build (and later the nightly) on a 32GB SanDisk microSD card. Sadly, in both cases Mobian is stuck during the plymouth boot screen (circle keeps circling indefinitely).
PostmarketOS works with this card, so I guess the microSD is not the problem. UBports is on the internal flash.
Any clue what the problem might be? Thanks.
(06-25-2020, 04:04 AM)The_Bolder Wrote: Hey all,
Hi!,
Maybe you can try another version in case that build you used is not working fine.
Also it could be the SD card was not created properly, what is your method to create the write the image onto the SD?
I used dd and made sure the card was unmounted.
I dug through the issue tracker and found that, apparently, there is some kind of problem with partition checking during boot. So maybe that's what causes the bootloop.
Update: using JumpDrive to flash it on the internal mmc worked! No clue what's going on with the microSD cards....
  Mobian MMS/SMS text problem bcnaz 16 35,491 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,033 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 61,824 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 69,555 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 2,943 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 326,807 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,644 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,580 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 4,263 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,038 04-29-2025, 02:10 PM
Last Post: mdk
