Sharing a breakout board I've made for the pogo pins
Hi all,
I've made a breakout board for the Pinephone's pogo pins. This might make the process of testing accessory hardware easier when it is in an early stage of development (e.g. not ready to be mounted directly to the phone).
Here is the Github repository with pictures of it installed and the KiCad source files: https://github.com/SMR404/PinephonePogoBreakout
Also, I made a Reddit post with the same (redundant) info: https://old.reddit.com/r/pinephone/comments/fa43gp/time_to_get_acquainted_with_the_expansion_port
I hope this is a help to some of you!
(02-29-2020, 02:15 PM)SMR404 Wrote: Hi all,
This could be super helpful for prototyping. Thanks so much for sharing!
On the software side, how do you program for I2C? Is there a Python or C++ library that can be used like an Arduino/microcontroller, and how do you adress the pins?
  PinePhone flex breakout board with Grove female header jnpine 0 2,189 08-04-2023, 10:47 PM
Last Post: jnpine
  Keyboard : replaced the logic board charging now working again grump_fiddle_reinstall 1 2,934 07-01-2023, 07:57 AM
  Pinephone keyboard poor pogo pin connection neil_swann80 2 5,910 03-08-2022, 10:57 AM
Last Post: neil_swann80
  Pogo pins flex breakout board jnpine 4 10,703 12-07-2020, 08:07 PM
Last Post: jnpine
  Thermal imaging solution board for the PinePhone board jnpine 2 6,785 12-04-2020, 04:27 PM
Last Post: jnpine
