Thermal imaging solution board for the PinePhone board
Hi all,
I just want to share my design for a sensor board that is planned to be used with the PinePhone along with a flex breakout board, I call it the PineEye.
The sensor is the Panasonic AMG8833 which is a grid-array infrared sensor which is used for thermal imaging.
Get design files here:
https://github.com/jnavarro7/pineeye_for_pinephone
Order boards directly from here:
https://oshpark.com/shared_projects/Z65YHSF2
I hope the community likes this projects and maybe start working on drivers which are still needed.
Please let me know of any comments or concerns.
I have done some initial test with the board, the sensor is seen by the PinePhone.
In the future I plan to create different sensor or peripheral boards for the PinePhone.
[Image: 2.png?raw=true]
Presumably it would work with libraries like the adafruit python one:
https://cdn-learn.adafruit.com/downloads...sensor.pdf
If it's aimed at the pinephone rather than more generic usage it should probably have the option to connect direct to the pogo pins similar to the way the breakout cable does. I'd be careful of proximity to the antenna.
I guess you've already seen Martijn Braam's post about the MLX90640:
https://blog.brixit.nl/making-a-backcove...pinephone/
(12-04-2020, 03:36 PM)wibble Wrote: Presumably it would work with libraries like the adafruit python one:
I tried the Adafruit one without success as of today. (Now reading Martjin´s post, as the work is aimed for the Raspberry Pi this might be why).
The direct connection could be for a later stage, the current system is aimed for prototyping.
Thanks a lot for the link, I have not seen it before.  I will for sure take a closer look at Martjin´s work!.
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,276 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 3,009 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 10,758 06-03-2025, 04:19 PM
Last Post: j_s
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,450 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 23,316 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 5,419 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,284 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 3,161 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 4,976 06-29-2024, 09:36 PM
  Was someone able to use the Pinephone keyboard & an usb mouse at the same? Peter Gamma 4 12,717 06-26-2024, 07:11 AM
Last Post: dachalife
