Is there any way to get a video output from a cluster module?
Or is IP TV streaming the only option? Or possibly x11 tunnel.
A remote desktop should work, see for example http://xrdp.org/
But why? Seems useless for the this specific hardware.
(06-12-2020, 01:47 PM)poVoq Wrote: A remote desktop should work, see for example http://xrdp.org/
Useless? Depends! If I want to have an ARM desktop computer, what are the choices? It's either multiple RockPro64, or the cluster, or both. So I have to spread out the applications somehow. Question is what's the best way to do it? Also I'm secretly hoping modular computing is the future.
I also got tip of Beowulf cluster.
This will not work as you seem to think... there is currently no way to combine the 7 boards to one "desktop" computer.
Better get a Odroid-N2 or such with is quite fast on it's own.
(06-13-2020, 05:51 PM)poVoq Wrote: This will not work as you seem to think... there is currently no way to combine the 7 boards to one "desktop" computer.
Obviously that depends on how possible it is to split up your tasks. If I'm doing web development, I can put the server on the board instead of my "main" SoC. Maybe some programs have high CPU time but less interactivity, in which cases tunneling could be worth it. And so on.
  Buy Cluster and Compute Modules jpotter 1 5,747 01-10-2022, 04:01 PM
Last Post: dcdc
  What's the point of a cluster? guenther 2 8,261 04-07-2021, 10:49 AM
Last Post: guenther
  Add ordinary so-dimm memory to cluster slot? fxSol 1 6,691 03-02-2021, 03:54 AM
Last Post: poVoq
  Is my wooden desk a safe surface to test the cluster board on? ollehar 6 15,336 12-28-2020, 09:41 AM
Last Post: robocone
  Building a new cluster with external storage hvdkooij 2 8,456 11-20-2020, 07:44 AM
Last Post: hvdkooij
  Compatibility between RPi Module and Cluster board leperotero 1 6,206 11-03-2020, 03:40 PM
Last Post: poVoq
  What kind of box would be able to host both the cluster board and a RockPro64? ollehar 1 6,027 06-14-2020, 05:37 PM
  USB3 with SoEdge module? poVoq 3 9,944 05-13-2020, 05:36 PM
Last Post: poVoq
  How much force does it take to insert a SOPINE module? jbobspants 0 3,689 01-17-2019, 12:15 PM
Last Post: jbobspants
  Compiling on the Sopine Cluster khaosgrille 3 9,585 08-10-2018, 06:17 AM
Last Post: khaosgrille
