What's the trick to get the battery to charge?
I'm messing around with the nuts and bolts on my device, trying to get a minimal PostmarketOS install working (eventually, I hope to have some fun trying to build my own UIs, which I'm sure will be a hilarious and educational programming challenge/disaster for myself). At the moment, though, I'm still hung up on trying to get the battery to charge. Even when plugged into a charger capable of delivering plenty of current, the battery continues to discharge, and the system never draws more than around half an amp.
Forgive me for being so clueless, but I'm new to all of this. What governs charging control, and how do I talk to it? Is this part of what 'crust' does? Charging appears to work fine under SailfishOS and Ubuntu, so I think hardware issues can be ruled out and I must just be missing some key thing on the software side.
I kinda had the same problem.
I had to open up the device as the contacts were loose. Reconnecting them properly fixed the problem for me.
(06-05-2020, 02:13 AM)Comiryu Wrote: I kinda had the same problem.
This can't be the problem for me, because the battery is definitely connecting; using the relevant sysfs handles (in /sys/class/power_supply), we can obtain its voltage, current, and capacity and such - it's just that it never starts charging, and only seems to discharge when present, even if external power is connected. I've double-checked the battery voltage with my multimeter, too, and it matches what the software reports, so I don't think this is a reporting error, either.
It feels like there must be some kind of electronically-controlled switch in there to engage charging mode that I haven't found yet.
  Battery life improvement freelectro 11 13,268 09-14-2026, 08:53 AM
Last Post: Juergen
  Battery connector dead mdk 5 5,481 01-15-2026, 02:24 PM
Last Post: mikeb
  Battery Life- hardware abstraction layer-GPU VS optomizing app for GPU-openGL biketool 1 4,016 09-20-2024, 04:04 AM
  Pinephone refusing to charge while suspended tiol 1 6,414 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 5,451 02-17-2024, 04:15 PM
Last Post: vortex
  PinePhone constantly vibrating and won't take charge ImmyChan 5 10,341 07-23-2023, 03:49 PM
Last Post: kb-zealot
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 5,647 03-20-2023, 12:54 AM
Last Post: bcoyle
  Power supply vs battery albafrati 11 14,006 06-22-2022, 06:04 PM
Last Post: albafrati
  What PD charger/dock combo results in PP battery not draining while using convergence james8880 0 3,900 04-28-2022, 12:45 PM
Last Post: james8880
  How to charge with 3 ampere / 5 volt / 15 watts? lacriz 3 6,554 03-10-2022, 11:09 AM
