Sxmo - Simple X Mobile Released for the Pinephone (new minimalistic UI & image)
Rainbow
Hi all,
I'm excited to announce the release of a new UI for the Pinephone I've been working on for a little while named Sxmo (which stands for Simple X Mobile). The concept is to use simple and suckless X programs to compose a fully functional Pinephone UI/OS setup. The UI includes texting/calls (via dmenu scripts navigatable with the Pinephone buttons), a good onscreen keyboard, a great terminal and browser, scripts for viewing youtube video/audio via mpv, RSS scripts via dmenu, and more. The core of the UI is based on a patched version of dwm (usable with the Pinephone buttons by differentiating single-double-triple clicking) and also the UI supports touch screen gestures as well.
Documentation and more about the Sxmo project is at:
http://sr.ht/~mil/Sxmo
Prebaked images (PmOS + Sxmo UI) are available at:
https://images.lrdu.org/pinephone/
Demo videos of the UI in use are here:
http://media.lrdu.org/sxmo_pinephone_demos/
And the userguide is here:
https://git.sr.ht/~mil/sxmo-docs/tree/ma...ERGUIDE.md
There's a lot that went into making the UI usable and there are still a few rough edges but it's working great for me and I'm looking to gather some feedback. Also I think the scripts, new C programs, and modifications to existing (mostly suckless) software that are in Sxmo may be helpful to others who are looking to make their own Pinephone UIs in a similar vein. In particular the dwm multikey patch makes using dwm on the PP quite possible by letting you differentiate commands by single/double/triple click of the hardware PP buttons; and lisgd, a new piece of software made for this project, is a great minimalistic way to manage touchscreen gestures on the PP.
I'm open to feedback on how to improve the project so feel free to put in patches/tickets over on sr.ht/~mil/Sxmo or comment here.
Edit:
Release notes for each new image are posted to the ML at:
https://lists.sr.ht/~mil/sxmo-devel
Also if anyone is curious about more in depth changes between versions - I setup a script to automatically generate an aggregated changelog so all changes can now be seen here:
https://git.sr.ht/~mil/sxmo-docs/tree/ma...ANGELOG.md
Nice Smile
(05-20-2020, 05:30 PM)mil Wrote: Hi all,
Cheers,
Miles
(05-20-2020, 05:30 PM)mil Wrote: I'm excited to announce the release of a new UI for the Pinephone I've been working on for a little while named Sxmo (which stands for Simple X Mobile).
On the desktop, dwm is my favourite WM. So, you have my attention Wink
I've downloaded the prebuild image of Sxmo, flashed it to sd-card and played with it for a while.
I like your work. Thanks!
i flashed to an sdcard also, pretty damn slick, nice work
This looks really slick & very useable! I'll try that later today!
Using khard (https://github.com/scheibler/khard/) as intermediate might make calling & texting easier (and I would sync it vdirsyncer (https://vdirsyncer.pimutils.org/en/stable/)) - but that's maybe outside the suckless - toolchain :-)
I've created a fresh pmos install by using pmbootstrap.
Then I've followed the install guide :
echo "http://sxmo.lrdu.org/alpine_repository/master" >> /etc/apk/repositories cd /etc/apk/keys && wget "https://git.sr.ht/~mil/sxmo-image-builder/blob/master/m%40milesalan.com-5e6e8e01.rsa.pub" apk update apk add sxmo-ui
But this gives me an error about untrusted signature. I've solved this bij adding --allow-untrusted to the apk commands. But I'm wondering what I'm doing wrong?
braveheart:/etc/apk/keys# cd /etc/apk/keys && wget "https://git.sr.ht/~mil/sxmo-image-builder/blob/master/m%40milesalan.com-5e6e8e01.rsa.pub" Connecting to git.sr.ht (173.195.146.142:443) saving to 'm%40milesalan.com-5e6e8e01.rsa.pub' m%40milesalan.com-5e 100% |******************************************************************************************************|   451  0:00:00 ETA 'm%40milesalan.com-5e6e8e01.rsa.pub' saved braveheart:/etc/apk/keys# apk update fetch http://postmarketos1.brixit.nl/postmarketos/master/aarch64/APKINDEX.tar.gz fetch http://dl-cdn.alpinelinux.org/alpine/edge/main/aarch64/APKINDEX.tar.gz fetch http://dl-cdn.alpinelinux.org/alpine/edge/community/aarch64/APKINDEX.tar.gz fetch http://dl-cdn.alpinelinux.org/alpine/edge/testing/aarch64/APKINDEX.tar.gz fetch http://sxmo.lrdu.org/alpine_repository/master/aarch64/APKINDEX.tar.gz ERROR: http://sxmo.lrdu.org/alpine_repository/master: UNTRUSTED signature WARNING: Ignoring APKINDEX.25860e17.tar.gz: No such file or directory 2020-05-20 14:53:59.316189 [http://postmarketos1.brixit.nl/postmarketos/master] v20200428-1568-g7b8a9ef2fc [http://dl-cdn.alpinelinux.org/alpine/edge/main] v20200428-1568-g7b8a9ef2fc [http://dl-cdn.alpinelinux.org/alpine/edge/community] v20200428-1566-gf80d15e6d5 [http://dl-cdn.alpinelinux.org/alpine/edge/testing] 1 errors; 16825 distinct packages available
Ok, found a solution for my "UNTRUSTED signature" problem.
sudo mv m\%40milesalan.com-5e6e8e01.rsa.pub m@milesalan.com-5e6e8e01.rsa.pub
(05-22-2020, 12:18 PM)janw Wrote: Ok, found a solution for my "UNTRUSTED signature" problem.
Thanks for trying it out on a pmOS install and figuring out the fix - updated the documentation on the install guide so nobody else will be caught on this step.
Eventually I'm going to try and get the Sxmo packages into pmOS proper so you should be able to install without the extra step of adding the secondary alpine repository - but maybe a little while before this comes through.
(05-22-2020, 01:15 AM)davidbe Wrote: This looks really slick & very useable! I'll try that later today!
Interesting - hadn't heard of `khard`, looks like its a vCard client. I've looked a bit into the vCard spec - looks (mostly) simple, atleast if the plain text variant is used. My current idea for a contact system currently is just to have a text file (tsv) with two columns number & contact name. Not sure yet, holding off building out the contact system work for a little while until some other bugs are fixed.
SXMO is SXE!!! Big Grin
this is a very exciting project. will be keeping my eye on it.
  PostmarketOS sxmo pinephone keyboard keymaps? afwtioane 2 6,204 09-11-2022, 04:37 AM
Last Post: manubert
  sxmo pim nextcloud Uturn 8 13,219 02-22-2022, 03:23 PM
Last Post: TRS-80
  Battery life on sxmo xark 1 4,247 02-12-2022, 10:07 AM
Last Post: TRS-80
  Official Channels for Sxmo Support anjanmomi 2 6,173 02-12-2022, 09:50 AM
Last Post: TRS-80
  sxmo & php --- 2 4,271 01-31-2022, 01:45 PM
Last Post: ---
  sxmo improvements unrealb2 7 11,925 11-17-2021, 06:43 AM
Last Post: fdlamotte
  SXMO on Debian IVp 0 4,278 08-21-2021, 02:33 PM
Last Post: IVp
  Megi's multiboot sxmo image aithal 1 4,231 06-14-2021, 08:07 AM
  SXMO svkbd with joypad layout [for basic dosbox play] streak 0 2,880 05-27-2021, 08:47 AM
Last Post: streak
  Sxmo on Arch IVp 4 11,281 05-19-2021, 03:18 AM
Last Post: dukla2000
