RTL8192EU WIFI
(02-28-2018, 04:02 PM)evilbunny Wrote:
(02-28-2018, 11:09 AM)elik745i Wrote: I've managed to install it through explorer, simply clicking on deb file and installing through GUI. After restart it seems like it's working! Thank you so much!
Could you please explain how did you compile the file so I do not bother you again in the future?
Again big thanks for your support!
The source code is extracted from the deb file and placed into /usr/src/rtl8192eu-4.4.1 and every time the kernel changes it will rebuild the module from source.
yes I understand that, but how did you compile deb file from driver files taken from github? For instance I have GPS module I got the linux driver files, but what steps need to be taken to compile deb file for ease of installation in my linux?
(03-01-2018, 10:43 AM)elik745i Wrote: yes I understand that, but how did you compile deb file from driver files taken from github? For instance I have GPS module I got the linux driver files, but what steps need to be taken to compile deb file for ease of installation in my linux?
I used the debian files from the rtl8812au driver that is in ubuntu repository and made some tweaks to it, like renaming in the files removing patches and running: ./debian/rules binary
I'm not sure if that will help with non realtek wifi drivers or not.
I bought the approved wifi dongle off the rock64 list and installed it the other day and it shows on debian as being online and It shows it connects with several wifi routers in the house but it will not work with firefox or chrome. I am not sure if it is getting data off the wifi but it shows it is connected. I can connect with firefox with eth0 or the wired conneection and it works great wired but the wifi don't . Any help or ideas would be great thanks.
  get wifi mt7601u mediatek usb dongle to work Johannes 0 6,284 11-17-2020, 09:48 AM
Last Post: Johannes
Information Rock64 RTL8188EU Wifi Adapter from Pine Store Tested Well MarkHaysHarris777 7 16,875 05-13-2020, 06:00 PM
Last Post: Leon Rembowski
  low speed wifi pas059 4 8,911 05-13-2019, 12:09 PM
Last Post: pas059
  Using ESP32 as WiFi and Bluetooth Module shripal17 2 6,684 03-08-2019, 02:44 AM
Last Post: shripal17
  50 kb with RTL8188eu WIFI adapter Juice4 2 6,060 11-09-2018, 12:56 PM
Last Post: Juice4
  WIFI driver compilation wsk 1 4,647 11-01-2018, 12:21 AM
Last Post: wsk
  Wifi; how to? scalextrix 12 26,711 05-30-2018, 12:20 AM
Last Post: scalextrix
  Very disappointed with ROCK64 USB WIFI 802.11B/G/N Danielsan 0 3,479 04-23-2018, 09:51 AM
Last Post: Danielsan
  None of my Wifi modules work NicoD 7 14,424 04-05-2018, 02:53 PM
  Yet another thread on ROCK64 Wifi Adapter Woes zendrummer74 1 5,629 02-01-2018, 11:10 PM
Last Post: a1w.ca
