Simple 3d Printed Case
I've currently got this printing...2 hours left on the bottom, then it's on to the top!
I also installed the debian image on my Pine (it just showed up today), and set it up to take the place of the rpi I currently have running OctoPrint. If all goes according to plan, the Pine case will be the last thing my rpi prints... Smile
(04-19-2016, 03:57 PM)ksolomon Wrote: I've currently got this printing...2 hours left on the bottom, then it's on to the top!
What 3D printer?
What 3D printer?
A Tevo Tarantula.  It's a low-end Prusa i3 clone, but unlike most i3's, this one has a full metal frame (built with 2020 aluminum extrusion).  They can be had on Ebay/Alibaba/etc for around $200-$250 for the base model.
Here's a shot of the test fit after the bottom finished.
(03-19-2016, 10:48 PM)kanthony Wrote: I designed a simple 3d printed case since there didn't seem to be one out there already. Nothing fancy but it works.
STLs available here: http://www.thingiverse.com/thing:1428977
I printed your design but both the times there was alignment issue - i.e. the top and bottom didn't properly close/align. Might be the original design itself.
Also, the smaller notches break VERY easily.
Can you please let me know what size screws are ideal to lock it down - your design said M3 - is that correct?
Some pics attached.
Photo Weatherproof case build ltorsini 12 41,277 07-07-2026, 07:01 PM
Last Post: ltorsini
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 99,071 07-23-2020, 05:31 AM
Last Post: devendraraju
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 7,243 11-12-2019, 04:52 AM
Last Post: xalius
  playbox case ribbon cable too short pinoosh 7 20,188 02-22-2019, 03:24 AM
Last Post: GaryFunk
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 18,746 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 30,299 07-18-2017, 10:39 AM
  A case with active cooling for 1Gb pine64 ishwest 5 16,554 06-28-2017, 04:05 AM
Last Post: ishwest
  Lego Case Kiryu 67 142,286 03-30-2017, 11:36 AM
Last Post: Luke
  Acrylic case with Lipo Holder and 2 Tactile push button included killor 9 22,351 10-24-2016, 08:18 AM
Last Post: killor
  Pine64 Layer case modmypi 2 8,989 10-04-2016, 02:45 AM
Last Post: modmypi
