Does #pinebook channel exists?
Looking at https://www.pine64.org/web-irc/ it is listed but getting list from freenode does not show it
Cheers
(03-20-2020, 02:43 PM)oxoocoffee Wrote: Looking at https://www.pine64.org/web-irc/ it is listed but getting list from freenode does not show it
Cheers
Just tested and works.
Cheers
Hmm, when I did try it it was not available. I did try to use external irc client and search for available channels. Good that is working again
as far I know, they are not using Freenode. it is posted here about that. I find it not so ideal but, it is just my opinion.
  Selling Pinebook Pro, PineNote and PineTab-V arw 3 2,234 10-29-2026, 03:14 PM
Last Post: arw
  Could Someone Give Advice on Optimising Pinebook Pro for Software Development? Octaviah 0 2,692 08-23-2024, 12:45 PM
Last Post: Octaviah
  [Pinebook Pro] Where to buy a new TFT and how to replace it? openbsd98324 2 3,666 07-23-2024, 07:14 AM
  Unable to connect to Pine64 IRC channel due to certificate error? Must-Borrow 1 3,549 03-10-2024, 02:43 PM
Last Post: Must-Borrow
  Pinebook Pro with RK3588? tantamount 28 30,106 07-13-2023, 04:06 PM
  The power of the Star64 vs Pinebook Pro/RockPro64 Starfall 1 3,764 04-17-2023, 05:00 AM
Last Post: lkoini
  Could an arm based pine 64 smaller than expected to go with the pinebook zanewiller 1 4,034 04-16-2022, 07:17 AM
Last Post: jiyong
  Could an arm based pine 64 smaller than normal to go with the pinebook zanewiller 0 3,494 04-06-2022, 01:30 AM
Last Post: zanewiller
Star Very Lightly Used PineBook Pro ragnarlothbrok64 4 7,142 01-21-2022, 02:36 PM
Last Post: sascha
  PINEBOOK Pro USB-C Docking Deck compatibility DevonBirch 1 3,968 08-01-2021, 05:13 PM
