USB-C dock
#61
Hi all,
Bought a dock that works great, just added it to the wiki.
Ugreen 50771 USB-C Dock 6-in-1 HDMI
https://www.aliexpress.com/item/32821301992.html (Multiple options on this page, I have only bought/tested 50771 6-in-1 HDMI)
HDMI: works!, Ethernet: works!, 3x USB: works!, USB-PD: works!
PD works with a HP 65W USB-C PD Charger (it does specify on the charger that it can do 5V3A)
PD works with a 5V3A USB-C charger (Tested using the Raspberry Pi 4 power supply)
PD does not work with a 5V2A charger.
Tested on Manjaro Arm 2020/03/18
#62
(03-18-2020, 05:49 PM)KiSM Wrote: Ugreen 50771 USB-C Dock 6-in-1 HDMI
Looks enticing. Can you confirm that there is also audio over hdmi?
If you have not tried it, does everything work at the same time, e.g. can you stream video over ethernet onto an external hdmi monitor while having some lightweight usb peripherals (such as a mouse and keyboard) plugged in?
#63
So I plugged in:
  • USB-C PD
  • Ethernet
  • HDMI
  • 3x usb devices (mouse, keyboard, usb game controller)
It all worked together great. No HDMI audio though.
#64
So I plugged in:
  • USB-C PD
  • Ethernet
  • HDMI
Thanks for the information and video. nload, eh? Smile
So, this dock is almost perfect.
#65
(03-20-2020, 11:52 PM)Der Geist der Maschine Wrote: Thanks for the information and video. nload, eh? Smile
Yeah, I can see this dock being very useful for many users if the HDMI audio worked. It seems to be a pretty common issue with USB-C docks though. Does anyone know if it's a driver or panfrost issue and could be potentially be resolved in software?
#66
Hey there, I am trying to get work my USB-C dock, when I connect it:
Quote:[ 3373.081079] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[ 3373.140880] typec_displayport port0-partner.0: No compatible pin configuration found:0000 -> 000c, 001c <- 0000
dmesg | grep firmware
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    4.919877] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   20.129515] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
Linux pinebookpro 5.5.0-1-pinebookpro-arm64 #1 SMP PREEMPT Wed Mar 18 06:26:22 UTC 2020 aarch64 GNU/Linux
In the default Debian I see:
Quote:cdn-dp fec00000.dp: [drm:cdn_dp_dpcd_read] *ERROR* dpcd read failed -22
cdn-dp fec00000.dp: [drm:cdn_dp_dpcd_check_sink_connection] *ERROR* Get sink capability timed out
cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] *ERROR* Enable dp failed -19
Is there any solutions?
PBP ISO / Debian Bullseye (unofficial installer)
#67
So I plugged in:
  • USB-C PD
  • Ethernet
  • HDMI
ugreen makes some good oddball connectors i see them on amazon all the time.
While most fear the darkness, for me it is home.
#68
So I plugged in:
  • USB-C PD
  • Ethernet
  • HDMI
 That on sure looks good! But I'd like to wait a bit until there's more news about the Pine rebranded on that was spoken about a bit earlier. Any news on that one?
#69
I've just purchased Ugreen 50771 6-in-1 HDMI. I have pinebook pro with Debian, I'm trying to choose Displays from the Control Center, but it doesn't detect the monitor.
However, it works as the usb-hub. Should I install some driver or so?
I checked it with my smartphone and it detects the monitor immediately with Ugreen connected.
#70
@leonidas, here are some things to try;
- Flip the USB cable around, some people found their USB C alt mode Display port devices only work one way.
- Try another distro of Linux known to work on the Pinebook Pro, like Manjaro which is shown to work with that device
Arwen Evenstar
Princess of Rivendale
  Pine Dock Networking Issue trillobite 1 3,730 02-10-2024, 12:03 AM
Last Post: trillobite
  Pinebook Pro Dock - cannot connect to monitor Dominik 4 7,564 06-12-2022, 10:53 AM
Last Post: Rosbeefandino
  Getting the dock to work. wove 2 7,187 12-27-2020, 09:27 AM
Last Post: wove
  Pinebook Pro Dock Power Requirements calinb 9 20,900 12-16-2020, 09:24 AM
Last Post: dsimic
  Pinephone dock with Pinebook Pro? karlnicholas 2 7,847 09-21-2020, 05:11 PM
Last Post: karlnicholas
  USB-C hub/dock/video Corkonian 2 8,354 11-02-2019, 02:29 PM
Last Post: Corkonian
