Wifi problem
#21
(03-02-2020, 06:15 AM)l_gyuri Wrote: No reboot needed. See:
https://gitlab.com/ubports/community-por..._296549402
Worked for me.
I tried this:
sudo nmcli radio all off
sudo rmmod 8723cs
sudo modprobe 8723cs
sudo nmcli radio all on
Did not work for me, still nothing found. We have a bunch of wifi signals here, so there should be plenty. If I tell it "nmcli r " it says everything is enabled, but no wifi networks listed. I start to think my phone has HW issues. Confused
#22
Worked for me.
I tried this:
sudo rmmod 8723cs
Now the wifi works, I'll test the mobile data too. So happy! Big Grin
#23
(02-03-2020, 02:36 PM)PinePhoneCoder Wrote: My wifi suddenly stopped working after sometime, but i got wifi working again after entering the folowing comments:
Open the terminal app and enter:
sudo nmcli radio wifi off
sudo nmcli radio wifi on
sudo reboot now
The pinephone reboots and I can connect with wifi again.
This totally works. Thanks buddy.
#24
sudo reboot now
i only need to turn the wifi radio off and on then its working , no need to reboot.
  Is there any way to tell CRUST to leave the wifi alone? Athansor 5 12,418 09-25-2020, 04:46 AM
Last Post: wibble
  Boot source problem. Issue confirmed. Thread renamed. Cree 2 6,680 08-26-2020, 12:47 PM
Last Post: Cree
  Any chance that we get WiFi texting/calling on UT? ragreenburg 0 3,558 08-04-2020, 09:13 AM
Last Post: ragreenburg
  wifi does not work - authentication problem? pphone-newbie 7 15,655 07-26-2020, 01:30 PM
Last Post: Cree
  Cellular switch (sw1) causes wifi to stop working blihp 4 10,545 07-21-2020, 10:30 PM
Last Post: blihp
  5Ghz Wifi Question LMalilil 3 9,449 07-10-2020, 03:09 PM
Last Post: hiimtye
  How to disable wifi MAC address randomization? dr.diesel 0 3,756 06-10-2020, 12:54 PM
Last Post: dr.diesel
  Dev 27 killed my Wifi Concrete_panda 1 4,557 05-18-2020, 12:09 PM
Last Post: colin hodsdon
