creating bootable remixOS/android MicroSD on Mac OS X or linux?
Question
hi all,
i've gone over the wiki instructions for creating a bootble RemixOS/Android MicroSD drive.
it seems, from these instructions, the only way to create this release MicroSD is using the PhoenixCard software, and that software only works on the Windows platform, and i have no windows machine.
  • is there any way to install the RemixOS/Android image without the Windows PhoenixCard software? Or is Windows with the Phoenix card the only way?
  • is there another, equivalent app that does the same thing in Mac OS X or any flaovr of Linux (those are the platforms i have)?
  • can it be done using Mac OS X/Linus 'dd' — i read ray hightower's quick start guide to pine64 with Mac OS X and attempted to try creating the RemixOS/Android image using those instructions with 'dd,' but the image i made on the MicroSD would not boot. is there another way to do this with 'dd' or some other app or command line utility?
please advise on this — thanks to all in advance.
best,
—  faddah
    portland, oregon, u.s.a.
(04-16-2016, 02:50 PM)faddah Wrote: hi all,
best,
—  faddah
We will create the Remix and Android build image that can be dd by Linux or MacOS on this week.
Rainbow
(04-17-2016, 09:09 AM)tllim Wrote: We will create the Remix and Android build image that can be dd by Linux or MacOS on this week.
oh cool! this is great news. i'll keep checking here in the forums and on the software part of the wiki for when that may come out. thanx!
also, i may have found another possible solution i am looking into for *Nix OS systems. i will let you know if i find anything worth reporting.
best,
—  faddah
faddah
best,
—  faddah
Noted, we will "standardize" on DD way for Android, Remix and Linux image (longsleep's Arch and Ubuntu), create 8GB, 16GB, and 32GB images so that user can burn the microSD card from Windows, OSX, and Linux OS enviroment.
We will release the Phoenixcard image for users that interest to try out, especially burn on different microSD card capacity such as 64GB or 128GB.
Hopefully this method will reduce newbie installation issue.
  StarPro64 Irradium (based on crux linux) riscv64, aarch64 mara 24 14,853 09-19-2026, 03:25 PM
  Star64 Irradium (based on crux linux) riscv64, aarch64 mara 20 20,133 07-18-2026, 06:16 PM
  Running Linux on Pinebook Pro with External Monitor Twers1962 2 3,410 03-25-2025, 11:10 PM
Last Post: Dendrocalamus64
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 3 6,706 12-10-2024, 07:23 PM
  linux-headers and quartz64-post-install package conflicts Berzerkleyfan 2 4,931 12-01-2023, 05:17 AM
Last Post: Berzerkleyfan
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 214,428 01-15-2020, 12:46 PM
Information Creating a NAS server in Pine64 javi_cala 4 12,426 01-21-2019, 02:03 AM
Last Post: bartes
  Creating bootable Debian backup image Drago 3 9,862 12-11-2018, 03:42 PM
Last Post: evilbunny
Question Do I need a touchscreen to run Android? chrbar 3 8,488 08-08-2018, 10:55 PM
Last Post: chrbar
  ethernet lan speed problem android fulltone 0 3,990 04-23-2018, 01:47 AM
Last Post: fulltone
