Suspend with NVME not working - Default Debian
Suspend stopped working after I installed an NVME drive.  It appears the PBP goes into suspend.   The screen goes black and the led turns red.  However, when pressing the power button the PBP will never wake up again.  I have to hold the power button 6 seconds to reset it and then boot from scratch.
The drive I installed was the Intel 660p SSDPEKNW512G8X1
I am setting power limiting on boot.  I added "sudo nvme set-feature /dev/nvme0 -f 2 -v 2" in /etc/rc.local and have verified that it is setting the feature correctly on boot.
Any ideas how to troubleshoot?  Has anyone else gotten suspend to work with an NVME drive installed?
This is probably related to the same nvme issues I solved for Linux on the Macbook Pro, recently. The drive would "sleep" but then resume as read-only - with unpredictable effects!
The Macs don't support APST, and many nvme units also seem to be "idiosyncratic" about implementations. The fix is to "turn-off" the ability of the kernel to impose sleep states on hardware that does not conform.
After researching a bit about this, my solution was:
echo 0 > /sys/bus/pci/devices/0000\:01\:00.0/d3cold_allowed
This is now featured on the authoritative  Dunedan /mbp-2016-linux github: https://github.com/Dunedan/mbp-2016-linux
This needs to be done in a root shell, sudo user won't cut it. You can elevate by runing 'sudo su -' and have a root shell, without additional login process.
I'd seriously give this a shot, AFTER you determine with lspci the actual device number for your nvme.
If this solves your problem, I supplied scripts and a systemd service wrapper, so you may automate at boot:
https://github.com/cb22/macbook12-spi-dr...-540208177
Create this file:
Quote:/etc/systemd/system/fix_sleep.service
# systemd oneshot service to set sleep boolean on Apple Macbook Pro disks
# Original by Pier Lim. Posted at https://kerpanic.wordpress.com/2018/03/1...in-ubuntu/
   [Unit]
   Description=Job that disables sleep from stopping nvme hardware on MBP
   [Service]
   ExecStart=/sbin/fixsleep
   Type=oneshot
   RemainAfterExit=yes
   [Install]
   WantedBy=multi-user.target
And the actual script:
Quote:/sbin/fixsleep
#!/bin/bash
/bin/echo 0 > /sys/bus/pci/devices/0000\:01\:00.0/d3cold_allowed
If you try this out, I'd love to hear how it goes.
— Jeremiah Cornelius
(02-06-2020, 08:06 PM)Jeremiah Cornelius Wrote: This is probably related to the same nvme issues I solved for Linux on the Macbook Pro, recently. The drive would "sleep" but then resume as read-only - with unpredictable effects!
Create this file:
   [Unit]
   [Service]
   Type=oneshot
   RemainAfterExit=yes
   [Install]
#!/bin/bash
My output from lspci:
00:00.0 PCI bridge: Device 1d87:0100
01:00.0 Non-Volatile memory controller: Intel Corporation Device f1a8 (rev 03)
Do I have to modify that command with this information somehow?
I tried this and it didn't work. I did sudo su,then from there I ran the command and hit suspend and the same wake issue occurred.
Create this file:
   [Unit]
   [Service]
   Type=oneshot
   RemainAfterExit=yes
   [Install]
#!/bin/bash
Hi Jeremiah,
Your suggestion works on imac models that have unofficial nvme setup running Debian. Do you have knowledge as to implementing same mechanism in macos since the issue is ongoing there as well. setpci maybe? Any clues?
Thanks,
Create this file:
   [Unit]
   [Service]
   Type=oneshot
   RemainAfterExit=yes
   [Install]
#!/bin/bash
Hi Jeremiah,
Thanks,
I'm afraid I'm way more familiar with being able to tinker with kernel internals of Linux, than MacOS.
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,003 04-04-2026, 08:00 AM
Last Post: qingss0
  Use SD to install new OS over pinebook debian Rudy558 10 27,551 03-09-2025, 11:17 AM
Last Post: davisthomas
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 2,469 09-27-2023, 08:53 PM
Last Post: pinemouth
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 2,706 07-13-2023, 01:50 PM
Last Post: PaulQ
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 477,128 05-12-2023, 06:09 AM
Last Post: korreckj328
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 5,846 04-23-2023, 06:58 AM
Last Post: acruhl
  bliuetooth not working in Armbian 22.11.1 Pinebook Pro River 0 2,054 12-09-2022, 04:48 PM
Last Post: River
  Installing Debian using files only from debian.org and encrypted root filesystem omarcomputing 0 2,272 10-08-2022, 11:03 AM
Last Post: omarcomputing
  U-Boot with direct NVMe boot support for eMMC/SPI Flash pcm720 125 323,402 09-27-2022, 07:41 AM
Last Post: olyavi
  Mid 2022: what is in your humble opinion the best working OS for the PinePro? walterbe 3 6,093 06-29-2022, 02:00 PM
Last Post: Chief
