Trackpad lack of fine movement and overrun ruining experience.
#21
(02-02-2020, 02:31 PM)mamboman777 Wrote: I tried to make these changes, but I think my x crashed. I ended up with a cursor. Using Manjaro. Trying to restore from SD, now.
Got it working. Major improvement. Thanks for the suggestion!
#22
You can use the keyboard as trackpad:
https://www.youtube.com/watch?v=JQJaJFZYPvI
#23
I've added the trackpad tuning for X-Windows to the Wiki;
Wiki - Pinebook Pro - X-Windows & trackpad tuning
As usual, feel free to correct, improve or comment, (good or politely bad).
Arwen Evenstar
Princess of Rivendale
#24
I've been having the same issues, too. Grabbing the corner of a window is practically impossible. I'll try the tuning suggested (thanks for your work on that, Jack, and to Arwen for updating the wiki).
I plan to get an wireless mouse at some point anyway, since I generally don't like using trackpads, but sometimes it's necessary (if I'm working from the couch, for example).
#25
(02-03-2020, 10:37 AM)inkslinger Wrote: I've been having the same issues, too. Grabbing the corner of a window is practically impossible. I'll try the tuning suggested (thanks for your work on that, Jack, and to Arwen for updating the wiki).
These are apparently called "resize handles" at least in plasma. You have some power to tweak them and should enable "Extended resize handles" if you can. Finding the settings may take some hunting.
I have always found these too small in any DE. OSX actually has a pretty complicated behavior that seems to track velocity at the window boarders to dynamically extend and apply the resize handles. I'm guessing Plasma isn't well developed there.
#26
I have found many Laptops are overly sensitive on the touch pads, sometimes this can be simply adjusted in the settings.
BUT sometimes it is not precise enough,
Learning to roll your finger on the track pad can make the difference rather than sliding your finger on the track pad. (?)
IF you turn down your setting enough for good precision, you barely move the cursor when you want to move the cursor across the screen !
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  Trackpad firmware update Luke 263 600,371 07-28-2021, 12:52 PM
Last Post: Luke
  My Experience Using the Pinebook Pro as a Daily Driver warpnow 9 17,851 06-22-2021, 02:30 PM
Last Post: moonwalkers
  Trackpad film clockcycles 5 10,243 06-18-2021, 09:34 PM
  User experience quadrantids 14 23,548 03-26-2021, 05:06 PM
Last Post: dsimic
  Lifting Trackpad p3pp3r 7 15,877 03-23-2021, 05:48 PM
Last Post: Timpanogos Slim
  Selling Pinebook Pro 128GB version (w/ NVMe adaptor) due to lack of use VoT 3 8,113 03-19-2021, 03:11 AM
Last Post: jj282
  No keyboard & trackpad leads to no display. RMA from the US. Free parts in Seattle BitterPine 4 15,220 12-30-2020, 06:14 AM
Last Post: BetteHoward
  Does this plastic trackpad cover come off? Paulie420 7 13,040 09-17-2020, 02:29 AM
  Mouse drfting when using the trackpad jcarty 1 4,922 09-15-2020, 03:21 PM
Last Post: ab1jx
  Trackpad sensitivity barn 1 4,790 08-06-2020, 01:03 PM
